You are here
  1. Home
  2. » Forums
Need help a copy cfe.bin
18 posts / 0 new
Andy Lee
Andy Lee's picture
My R6200v1 accident brick on setup. Serial output just hang in there:
Decompressing..........done
CFE for R6200 version: v1.0.1
Build Date: Fri May 11 13:46:43 CST 2012
Init Arena
Init Devs.
Found an ST compatible serial flash with 256 64KB blocks; total size 16MB
CPU type 0x19740: 480MHz
Tot mem: 131072 KBytes
All ethernet port not work. I guest cfe partition corrupt. Anybody can dump cfe for me ? Pls help.
Sayan Mukherjee
Sayan Mukherjee's picture
Are you getting any other
Are you getting any other message during boot or only the messages that you have mentioned above?
Moreover, are you able to enter the CFE mode by using Ctrl+C during boot.
Andy Lee
Andy Lee's picture
Hi Sayan.
Hi Sayan.
No other message, no more.
I can enter cfe> by ctrl-c, can boot firmware by cfe>go command, but ethernet switch not work and not detected.
I think cfe bootloader missing info to detect switch chipset or maybe switch chip died.
Sayan Mukherjee
Well, what are the problems
Well, what are the problems you are facing?
Ethernet is not working at CFE or ethernet is not working after firmware booting? or both?
Did you try 30-30-30 reset (hard reset) ? If not, you may try it.
Unless I know the exact problem, I am unable to help you...
Andy Lee
Andy Lee's picture
Ethernet not work on both at
Ethernet not work on both at CFE & after firmware boot.
I also try 30/30/30 but not effect.
The problem is accident when I change some option in GUI config (dns, ip adress..), after I save & apply, router bicked.
Sayan Mukherjee
Okay...
Okay...
Could you please send me the result you are getting by firing the command
"nvram show" in the console.
But before that please perform a 30-30-30 reset. And boot the firmware.
Andy Lee
Andy Lee's picture
NVRAM SHOW:[/code
NVRAM SHOW:
[/code]
Init Arena
Init Devs.
Startup canceled
CFE> ^C
CFE> nvram show
sb/1/ofdm2gpo=0x75331111
sb/1/elna2g=3
boardrev=0x1101
sb/1/mcs2gpo0=0x1000
et0macaddr=84:1b:5e:ee:2e:cd
sb/1/mcs2gpo1=0x7531
sb/1/mcs2gpo2=0x2111
sb/1/mcs2gpo3=0xA864
sb/1/mcs2gpo4=0x3333
sb/1/mcs2gpo5=0x9864
boot_wait=off
watchdog=3000
sb/1/mcs2gpo6=0x3333
sb/1/mcs2gpo7=0xB975
et0mdcport=0
reset_gpio=3
pmon_ver=CFE 2010.09.30.0
vlan2ports=4 8u
sb/1/triso2g=4
sb/1/sromrev=8
gpio5=robo_reset
sb/1/pa2gw2a0=0xFA18
sb/1/pa2gw2a1=0xFA4B
sromrev=8
boardtype=0xF52C
et1macaddr=84:1b:5e:ee:2e:ce
lan_netmask=255.255.255.0
boardpwrctl=0xd0068000
sb/1/regrev=0
sb/1/ag0=0
sb/1/ag1=0
sb/1/ag2=0
vlan2hwname=et0
sb/1/extpagain2g=3
xtalfreq=20000
sb/1/stbcpo=0x1111
boardflags2=0x00110402
sb/1/aa2g=3
sb/1/bwduppo=0
sb/1/txchain=3
boardmfg=NETGEAR
cfe_version=v1.0.1
wait_time=3
sb/1/pa2gw1a0=0x191D
sb/1/pa2gw1a1=0x1809
sb/1/boardflags2=0x00110402
sb/1/boardflags=0x00001310
sb/1/leddc=0xFFFF
clkfreq=480,240,120
lan_ipaddr=192.168.1.1
vlan1hwname=et0
sdram_config=0x0104
vlan1ports=0 1 2 3 8*
sb/1/macaddr=00:90:4C:02:50:01
sb/1/ccode=0
sdram_refresh=0x183f
wandevs=et0
sb/1/cck2gpo=0x1111
sdram_ncdl=0x6a26162a
sb/1/pa2gw0a0=0xFEA6
sb/1/pa2gw0a1=0xFE9E
sb/1/devid=0x4329
sb/1/bw40po=0x0000
et0phyaddr=30
sb/1/pdetrange2g=5
landevs=vlan1 wl0 wl1
sb/1/tssipos2g=1
sdram_init=0x0000
sb/1/antswctl2g=2
sb/1/ledbh0=11
sb/1/maxp2ga0=0x56
sb/1/ledbh1=11
sb/1/maxp2ga1=0x56
sb/1/ledbh2=11
sb/1/ledbh3=11
sb/1/cddpo=0x1111
sb/1/rxchain=3
boardnum=01
sb/1/antswitch=0
size: 1495 bytes (64041 left)
*** command status = 0
[code]
Message after Go command:
[/code]
CFE> go
Checksum mismatch:
Image chksum: 0xCAC16766
Calc  chksum: 0xA1CF67D7
Loading: .. 3916 bytes read
Entry at 0x80001000
Linux version 3.10.41-rc1 ([email protected]) (gcc version 4.1.2) #28 Mon Oct 27 17:46:36 IST 2014
CPU revision is: 00019740 (MIPS 74Kc)
found nvram at FF0000
something wrong here. do not remap
Determined physical RAM map:
 memory: 07fff000 @ 00000000 (usable)
Zone ranges:
  Normal   [mem 0x00000000-0x07ffefff]
  HighMem  empty
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x00000000-0x07ffefff]
Primary instruction cache 32kB, 4-way, VIPT, I-cache aliases, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32511
Kernel command line: console=ttyS0,115200 root=1f05 rootfstype=squashfs noinitrd init=/bin/sh
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Writing ErrCtl register=00000000
Readback ErrCtl register=00000000
Memory: 125064k/131068k available (3116k kernel code, 6004k reserved, 666k data, 308k init, 0k highmem)
NR_IRQS:128
CPU: BCM4716 rev 1 at 480 MHz
bcm947xx_clockevent_set_mode: 1
bcm947xx_clockevent_set_mode: 3
console [ttyS0] enabled
Calibrating delay loop... 239.61 BogoMIPS (lpj=1198080)
pid_max: default: 32768 minimum: 301
bio: create slab at 0
PCI: Using membase 8000000
PCI: Initializing host
PCI: Reset RC
PCI: no core
PCI: scanning bus 0
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
pci_bus 0000:00: root bus resource [bus 00-ff]
PCI: Fixing up bus 0
pci 0000:00:05.0: bridge configuration invalid ([bus 00-00]), reconfiguring
PCI/PCIe coreunit 0 is set to bus 1.
PCI: Fixing up bridge
PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
PCI: Fixing up bus 1
Switching to clocksource MIPS
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
WNDR4000/R6200 GPIO Init
msgmni has been set to 244
alg: No test for stdrng (krng)
io scheduler noop registered (default)
HDLC line discipline maxframe=4096
N_HDLC line discipline registered.
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 8) is a U6_16550A
brd: module loaded
found WNDR4000 / R6200
try to find cfe size up to 16777216
bootloader size: 262144
nvram size: 65536
bcmsflash: Filesystem type: squashfs, size=0xbf2a2c
partition size = 0
Creating 6 MTD partitions on "bcmsflash":
0x000000000000-0x000000040000 : "cfe"
0x000000040000-0x000000f40000 : "linux"
0x000000184800-0x000000d80000 : "rootfs"
mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
mtd: partition "rootfs" set to be root filesystem
0x000000ff0000-0x000001000000 : "nvram"
0x000000f40000-0x000000fe0000 : "ddwrt"
0x000000fe0000-0x000000ff0000 : "board_data"
brcmnand: found no supported devices
nflash: found no supported devices
tun: (C) 1999-2004 Max Krasnyansky
PPP BSD Compression module registered
PPP Deflate Compression module registered
Broadcom Watchdog Timer: 0.07 initialized.
GACT probability NOT on
Mirror/redirect action on
Failed to load ipt action
Simple TC action Loaded
netem: version 1.3
u32 classifier
    Performance counters on
    input device check on
    Actions configured
nf_conntrack version 0.5.0 (1954 buckets, 7816 max)
nf_conntrack_rtsp v0.6.21 loading
ip_set: protocol 6
gre: GRE over IPv4 demultiplexor driver
nf_nat_rtsp v0.6.21 loading
TCP: bic registered
TCP: cubic registered
TCP: westwood registered
TCP: highspeed registered
TCP: hybla registered
TCP: htcp registered
TCP: vegas registered
TCP: veno registered
TCP: scalable registered
TCP: lp registered
TCP: yeah registered
TCP: illinois registered
Bridge firewalling registered
8021q: 802.1Q VLAN Support v1.8
startup nvram driver
found nvram
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing unused kernel memory: 308K (803b3000 - 80400000)
start service
starting Architecture code for broadcom
starting hotplug
Jan  1 00:00:02 udevtrigger[743]: parse_config_file: can't open '/etc/udev/udev.conf' as config file: No such file or directory
done
boardnum 01
boardtype 0xF52C
boardrev 0x1101
nvram invalid, erase
Booting device: Netgear R6200
get_wl_instance doesnt return the right value 0
No such device
Need reboot now .....
kill -15 -1: No such file or directory
sleep 3: No such file or directory
kill -9 -1: No such file or directory
umount -a -r: No such file or directory
loading et
et: module license 'Proprietary' taints kernel.
et_module_init: txworkq set to 0x0
et_module_init: et_txq_thresh set to 0x400
network todo 'eth%d' but state 0
CPU: 0 PID: 990 Comm: insmod Tainted: P             3.10.41-rc1 #28
Stack : 00000000 00000000 80466be2 00000043 00000000 00000000 00000000 00000000
          00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
          00000000 00000000 00000000 00000000 00000000 00000000 00000000 87077af8
Call Trace:[<8001bec0>] 0x8001bec0
[<801f9ca0>] 0x801f9ca0
[<801f9c30>] 0x801f9c30
[<8716064c>] 0x8716064c
[<8716f4d0>] 0x8716f4d0
[<8716f250>] 0x8716f250
[<80007264>] 0x80007264
[<800816f8>] 0x800816f8
[<800f46f8>] 0x800f46f8
[<800f484c>] 0x800f484c
[<801527d4>] 0x801527d4
[<80152c20>] 0x80152c20
[<80179548>] 0x80179548
[<8004fa9c>] 0x8004fa9c
[<8017973c>] 0x8017973c
[<801796c4>] 0x801796c4
[<8030a2c0>] 0x8030a2c0
[<80179b60>] 0x80179b60
[<80179bd0>] 0x80179bd0
[<80175eec>] 0x80175eec
[<80177fa0>] 0x80177fa0
[<8030a200>] 0x8030a200
[<80178bc4>] 0x80178bc4
[<80178b8c>] 0x80178b8c
[<8716f000>] 0x8716f000
[<80179fbc>] 0x80179fbc
[<8000ddbc>] 0x8000ddbc
[<8004b7f8>] 0x8004b7f8
[<80095d7c>] 0x80095d7c
[<80061a60>] 0x80061a60
[<8006002c>] 0x8006002c
[<80061f90>] 0x80061f90
[<80061ff8>] 0x80061ff8
[<800a4068>] 0x800a4068
[<80006d44>] 0x80006d44
[<800051a8>] 0x800051a8
loading switch-core
loading switch-robo
roboswitch: Probing device 'eth0'
roboswitch: No such device
roboswitch: Probing device 'eth1'
roboswitch: Probing device 'eth2'
roboswitch: Probing device 'eth3'
insmod: cannot insert '/lib/modules/3.10.41-rc1/kernel/drivers/net/switch/switch-robo.ko': No such device
insmod: emf.ko: module not found
insmod: igs.ko: module not found
[USB] checking...
umount: can't umount /mnt: No such file or directory
rmmod: usblp: No such file or directory
rmmod: printer: No such file or directory
rmmod: usb-storage: No such file or directory
rmmod: sr_mod: No such file or directory
rmmod: cdrom: No such file or directory
rmmod: sd_mod: No such file or directory
rmmod: scsi_wait_scan: No such file or directory
rmmod: scsi_mod: No such file or directory
rmmod: usbmisc_imx: No such file or directory
rmmod: ci13xxx_imx: No such file or directory
rmmod: ci_hdrc: No such file or directory
rmmod: phy-mxs-usb: No such file or directory
rmmod: fsl-mph-dr-of: No such file or directory
rmmod: usb-libusual: No such file or directory
rmmod: dwc_otg: No such file or directory
rmmod: xhci-hcd: No such file or directory
rmmod: usb-ohci: No such file or directory
rmmod: ohci-hcd: No such file or directory
rmmod: uhci-hcd: No such file or directory
rmmod: usb-uhci: No such file or directory
rmmod: ehci-pci: No such file or directory
rmmod: ehci-platform: No such file or directory
rmmod: ehci-hcd: No such file or directory
rmmod: usbcore: No such file or directory
rmmod: usb-common: No such file or directory
rmmod: xfs: No such file or directory
rmmod: msdos: No such file or directory
rmmod: vfat: No such file or directory
rmmod: fat: No such file or directory
rmmod: nls_utf8: No such file or directory
rmmod: nls_iso8859-2: No such file or directory
rmmod: nls_iso8859-1: No such file or directory
rmmod: nls_cp437: No such file or directory
rmmod: nls_cp932: No such file or directory
rmmod: nls_cp936: No such file or directory
rmmod: nls_cp950: No such file or directory
rmmod: nls_base: No such file or directory
rmmod: ext3: No such file or directory
rmmod: jbd: No such file or directory
rmmod: ext2: No such file or directory
rmmod: mbcache: No such file or directory
rmmod: fuse: No such file or directory
/etc/preinit: line 66: can't create /proc/sys/net/ipv4/ip_conntrack_max: nonexistent directory
eth0: Operation not supported
wl0.1: No such device
wl0.2: No such device
wl0.3: No such device
eth0: Operation not permitted
nbw = 20
channel 6, val 20
0, 1000, 0, 6
spec 1006
wl: Unsupported
emf: No such file or directory
device br0 entered promiscuous mode
device br0 left promiscuous mode
ifconfig: ioctl 0x8914 failed: Cannot assign requested address
function start_hwmon not found
cp: can't stat '/tmp/mycron.d/*': No such file or directory
cp: can't stat '/jffs/mycron.d/*': No such file or directory
cp: can't stat '/mmc/mycron.d/*': No such file or directory
rmmod: n_hdlc: No such file or directory
ifconfig: ioctl 0x8913 failed: No such device
SIOCGIFFLAGS: No such device
ifconfig: SIOCSIFTXQLEN: No such device
udhcpc: ioctl 0x8933 failed: No such device
/bin/sh: /opt/etc/init.d/rcS: not found
/bin/sh: /jffs/etc/init.d/rcS: not found
/bin/sh: /mmc/etc/init.d/rcS: not found
rmmod: ipt_webstr: No such file or directory
rmmod: ipt_layer7: No such file or directory
rmmod: xt_layer7: No such file or directory
rmmod: ipt_ipp2p: No such file or directory
rmmod: xt_ipp2p: No such file or directory
insmod: ipt_mark.ko: module not found
insmod: xt_mark.ko: module not found
insmod: ipt_CONNMARK.ko: module not found
insmod: xt_CONNMARK.ko: module not found
rmmod: nf_nat_pptp: No such file or directory
rmmod: nf_conntrack_pptp: No such file or directory
rmmod: nf_nat_proto_gre: No such file or directory
rmmod: nf_conntrack_proto_gre: No such file or directory
rmmod: ip_nat_pptp: No such file or directory
rmmod: ip_nat_proto_gre: No such file or directory
rmmod: ip_conntrack_pptp: No such file or directory
rmmod: ip_conntrack_proto_gre: No such file or directory
killall: proxywatchdog.sh: no process killed
insmod: ip_conntrack_proto_gre.ko: module not found
insmod: ip_nat_proto_gre.ko: module not found
insmod: ip_conntrack_pptp.ko: module not found
insmod: ip_nat_pptp.ko: module not found
killall: schedulerb.sh: no process killed
Bad argument `MARK'
Error occurred at line: 4
Try `iptables-restore -h' or 'iptables-restore --help' for more information.
killall: wdswatchdog.sh: no process killed
rmmod: xt_physdev: No such file or directory
rmmod: xt_IMQ: No such file or directory
rmmod: ipt_IMQ: No such file or directory
rmmod: imq: No such file or directory
rmmod: sch_codel: No such file or directory
rmmod: sch_fq_codel: No such file or directory
connect: Network is unreachable
gethostbyname: Network is unreachable
[code]
(note: I removed 5Ghz module)
Sayan Mukherjee
Thanks a lot for the
Thanks a lot for the information.
But I need to know the output of "nvram show" after the existing firmware boots.
Moreover, though it is obvious that you are sure about the issue of ethernet, still it will be safe to cross check the network status of the corresponding interface of your pc (The network manager your PC or any tool used for this purpose). I mean the link status, half duplex/full duplex, speed etc.
Andy Lee
Andy Lee's picture
Im sure all ethernet on
Im sure all ethernet on router dead. I also check with two pc, no led, status of network cable still unplug...etc.
nvram show after reset & firmware boot:
root@DD-WRT:~# nvram show
pci/1/1/mcsbw805glpo=0x0
sb/1/ofdm2gpo=0x86666666
ses_script=
filter_dport_grp3=
wl_mac_deny=
wl0.1_radius_port=1812
wl0_wds2_if=
olsrd_coverage=7
http_redirect_port=3128
filter_dport_grp4=
wl0_wds10_ospf=
oet5_en=0
wan_unit=0
filter_dport_grp5=
filter=on
oet2_fragment=0
sb/1/elna2g=3
sv_localdns=0.0.0.0
filter_dport_grp6=
wl0_wmf_bss_enable=0
wl0_net_mode=mixed
wds0.1=
NC_Verbosity=2
nvram_ver=3
filter_dport_grp7=
wl0_rifs_advert=auto
chilli_interface=
wds0.2=
altdns1=
openvpncl_ip=
openvpn_lzo=adaptive
filter_dport_grp8=
wl_txstreams=0
wl0_frameburst=off
wds0.3=
altdns2=
openvpncl_client=
oet3_fragment=0
pppoeserver_idle=0
filter_dport_grp9=
wl0_txbf=0
wds0.4=
altdns3=
wds_watchdog_interval_sec=1000
oet8_bridged=1
log_ipaddr=0
ddns_username_2=
pptpd_mtu=1436
wds0.5=
zebra_log=0
oet2_ipaddr=1.2.3.4
oet9_pt=0
pci/1/1/mrrs=128
boardrev=0x1101
ddns_username_3=
chilli_enable=0
hotss_enable=0
wl0_wds3_desc=
wl0_wds7_ospf=
wds0.6=
NC_RenewTimeout=0
oet2_shaper=0
oet4_fragment=0
pci/1/1/sb20in80and160lr5gmpo=0
ppp_passwd=
ppp_idletime=5
ddns_username_4=
wds0.7=
pci/1/1/aa5g=3
ddns_username_5=
wds0.8=
zebra_copt=0
NC_SplashURL=
openvpncl_enable=0
pppoeserver_mppc=0
radius_expiration=365
pci/1/1/sar5g=15
pci/1/1/mcsbw805ghpo=0x99552222
ddns_username_6=
wds0.9=
eth2_netmask=0.0.0.0
oet5_fragment=0
oet8_ipaddr=1.2.3.4
sb/1/mcs2gpo0=0x6666
ddns_username_7=
openvpn_dupcn=0
oet8_shaper=0
qos_done=0
sb/1/mcs2gpo1=0xB966
wl0_leddc=0x640000
wl0.3_key=1
ddns_enable=0
ddns_username_8=
snmpd_rocommunity=public
pci/1/1/rawtempsense=0x1ff
sb/1/mcs2gpo2=0x6666
wl0_bw_cap=255
wl0_ipaddr=0.0.0.0
NC_MaxMissedARP=5
openvpn_mtu=1400
oet6_fragment=0
oet10_ipaddr=1.2.3.4
oet10_shaper=0
sb/1/mcs2gpo3=0xB966
wl0_shortslot=auto
wl0.2_radius_port=1812
ddns_conf=
skip_intel_check=0
NC_MACWhiteList=
pci/1/1/mcsbw1605gmpo=0
sb/1/mcs2gpo4=0xAAAA
wan_get_dns=
wl0_akm=disabled
ddns_hostname_buf=
wl_maxassoc=128
oet3_rem=192.168.90.1
sb/1/mcs2gpo5=0xCBAA
boot_wait=on
watchdog=3000
syslogd_rem_ip=
openvpncl_key=
oet7_fragment=0
sb/1/mcs2gpo6=0xAAAA
filter_web_host1=
wl_phytypes=
nas_enable=1
proftpd_authserverport=1812
wl0_infra=1
sb/1/mcs2gpo7=0xCBAA
filter_web_host2=
wl0.2_netmask=0.0.0.0
hotss_uamallowed=
wl0_country_code=DE
et0mdcport=0
fw_disable=0
filter_web_host3=
eth6_netmask=0.0.0.0
pci/1/1/tworangetssi5g=0
filter_web_host4=
pppoe_keepalive=0
router_name=DD-WRT
wl0_wds1_desc=
wl0_wds5_ospf=
wl0_wds1_if=
openvpn_dh=
pptpd_client_srvsub=
oet4_netmask=255.255.255.0
oet8_fragment=0
auth_limit=180
filter_web_host5=
wshaper_enable=0
oet4_en=0
pci/1/1/rxgains2gtrisoa0=0
filter_web_host6=
https_enable=0
wl_distance=2000
ddns_wildcard=
l2tp_ref_pap=yes
wl0_wds6_enable=0
wd_url=
eth0_ipaddr=0.0.0.0
pci/1/1/rxgains2gtrisoa1=0
filter_web_host7=
wl_infra=1
wl0.2_wpa_psk=
apwatchdog_enable=0
oet9_fragment=0
dlna_enable=0
pci/1/1/rxgains2gtrisoa2=0
reset_gpio=3
ses_event=2
filter_web_host8=
l2tp_get_ip=
pptp_iptv=0
hotss_customuamproto=https
telnet_wanport=23
wl0_wds3_netmask=
svqos_port2bw=FULL
openvpncl_config=
usb_automnt=0
pppoeserver_authserverport=1812
filter_web_host9=
wl0_txchain_pwrsave_enable=0
dhcpfwd_ip=0.0.0.0
pppoeserver_authserverip=192.168.1.1
samba3_dirpath=/jffs
wl0_bcn_rotate=0
ppp_get_ac=
wl_stbc_tx=auto
pptp_server_ip=
pptpd_forcemppe=1
radio1_on_time=111111111111111111111111
pppoeserver_clip=local
pci/1/1/sb20in40lrpo=0x0
restore_defaults=0
ddns_time=
pptpd_bcrelay=0
eth6_ipaddr=0.0.0.0
oet8_pt=0
pppoeserver_chaps=
pci/2/1/ccode=US
pci/1/1/sb40and80lr5gmpo=0
vlan2ports=4 8
wl0_cal_period=0
hotss_locationid=
wl0_wds5_hwaddr=
pptp_use_dhcp=1
oet8_netmask=255.255.255.0
wl0_br1_netmask=255.255.255.0
wl0_bandlist=b
wl0.1_hwaddr=02:90:4C:02:50:02
wl0.1_key=1
wl0.3_radius_port=1812
wl0.3_radius_key=
wshaper_downlink=0
pci/1/1/pcieingress_war=15
ppp_username=
wl0_atf=0
wl0_wds10_hwaddr=
pptpd_client_srvip=
oet9_id=1
wan_lease=86400
filter_port=
wl0_nctrlsb=lower
wl0_wme_sta_be=15 1023 3 0 0 off
openvpn_pkcs12=
pci/1/1/_mrrs=128
pci/1/1/noiselvl5gla0=31
sb/1/triso2g=4
wl0.3_auth_mode=disabled
ddns_enable_buf=
wl_wme_apsd=on
eth10_bridged=1
oet1_rem=192.168.90.1
oet3_mssfix=0
olsrd_lqaging=0.1
pci/1/1/noiselvl5gla1=31
sb/1/sromrev=8
filter_ip_grp1=
http_wanport=8080
wl0.2_ssid=
ddns_hostname=
wl0_wds7_netmask=
wl0_wds3_ospf=
ip_conntrack_tcp_timeouts=3600
dlna_cleandb=0
pci/1/1/agbg0=71
pci/1/1/noiselvl5gla2=31
lan_gateway=0.0.0.0
filter_ip_grp2=
openvpn_redirgate=0
usb_ohci=0
pppoeserver_bsdcomp=0
pci/1/1/agbg1=71
pci/1/1/mcsbw405glpo=0x0
wl0_ifname=eth0
filter_ip_grp3=
hwmon_temp_hyst=50
usb_storage=0
pci/1/1/agbg2=133
pci/1/1/epagain2g=0
lan_domain=
filter_ip_grp4=
dr_lan_rx=0
hotss_net=192.168.182.0/24
transmission_dir=/jffs/transmission
timer_interval=3600
filter_ip_grp5=
wl0_wds4_ipaddr=
snmpd_rwcommunity=private
wl0_wme_sta_bk=15 1023 7 0 0 off
oet9_mssfix=0
reconnect_enable=0
filter_ip_grp6=
hs_html=
log_accepted=0
openvpn_clcon=
pptpd_client_srvsec=mppe required
filter_rule1=
filter_ip_grp7=
pppoe_ac=
chilli_backup=0.0.0.0
wshaper_uplink=0
pptpd_client_ipparam=
ses_button=0
filter_rule2=
filter_ip_grp8=
ipsec_pass=1
hb_server_ip=
pci/1/1/gainctrlsph=0
gpio5=robo_reset
ses_enable=1
filter_rule3=
filter_ip_grp9=
rflow_enable=0
pptpd_radserver=0.0.0.0
wl0_wds0_if=
openvpncl_remoteip=0.0.0.0
expert_mode=1
filter_rule4=
wl0.2_key1=
schedule_minutes=0
oet3_en=0
pppoeserver_lcpechofail=12
pci/1/1/papdcap5g=0
pci/1/1/noiselvl5gha0=31
filter_rule5=
wl0.2_key2=
port5vlans=1 2 16
openvpncl_cipher=bf-cbc
pci/1/1/sb20in80and160hr5gmpo=0
pci/1/1/noiselvl5gha1=31
filter_rule6=
filter_ip_grp10=
wl0.2_key3=
wl0_mrate=0
hotss_interface=
openvpncl_tlscip=0
pci/1/1/noiselvl5gha2=31
wan_gateway=
filter_rule7=
wl0_mode=ap
wl0.2_key4=
wol_passwd=
pci/1/1/mcsbw405ghpo=0x33330000
filter_rule8=
dhcp_start=100
pptpd_radpass=
wl0_wds1_ospf=
openvpncl_fragment=
filter_rule9=
wl0_stbc_tx=auto
chilli_uamanydns=0
wl0_ap_isolate=0
pptpd_enable=0
oet7_pt=0
pci/1/1/tempcorrx=0x3f
filter_services_1=
wl_mrate=0
chilli_uamallowed=
svqos_port4prio=10
openvpn_client=
oet3_ipaddr=1.2.3.4
proftpd_anon_subdir=
sb/1/itt2ga0=0x20
ddns_force=10
l2tp_server_ip=
chilli_radius=0.0.0.0
wshaper_nopriohostsrc=
NC_DocumentRoot=/www
oet3_shaper=0
sb/1/itt2ga1=0x20
sromrev=8
dhcp_lease=1440
wl0_ampdu=auto
wl0_gmode=1
wl0_wme_no_ack=off
wd_interval=60
oet8_id=1
samba3_pubacl=1
pci/1/1/tssiposslope5g=1
pci/1/1/mcslr5gmpo=0
remote_ip_any=1
wds_watchdog_ips=
openvpn_proto=udp
wd_extiface=
eth3_bridged=1
3gdata=
boardtype=0xF52C
wl0.2_wpa_gtk_rekey=3600
limit_ssh=0
openvpn_enable=0
oet1_bridged=1
oet9_ipaddr=1.2.3.4
proftpd_passw=
is_default=1
wl_ampdu_rr_rtylimit_tid=2 2 2 2 2 2 2 2
wl_obss_coex=0
dnsmasq_enable=1
chilli_additional=
oet9_shaper=0
wl0_nband=0
wl_ampdu=auto
port3vlans=1
eth10_netmask=0.0.0.0
stats_server=
pci/1/1/rxchain=3
static_route=
wd_gwport=2060
need_commit=1
wl0_nreqd=0
NC_extifname=auto
sip_port=5060
openvpncl_ca=
wl0.3_bridged=1
wl0.1_crypto=off
wl0_security_mode=disabled
radvd_conf=
openvpncl_tlsauth=
pptpd_client_mtu=1436
dmz_enable=0
wl0_wds1_enable=0
wl0_wme_txp_be=7 3 4 2 0
eth7_bridged=1
ttraff_iface=
http_source_network=0.0.0.0
http_username=bJ/GddyoJuiU2
wl0_ssid=dd-wrt
wl0_dtim=1
wl_wme_sta_vi=7 15 2 6016 3008 off
oet5_bridged=1
wifi_display=wl0
port_trigger=
oet2_en=0
pci/1/1/cckbw202gpo=0
pci/1/1/sb40and80hr5gmpo=0
pci/1/1/maxp5ga0=60,90,90,90
filter_web_host10=
wl_wme_ap_be=15 63 3 0 0 off
wd_httpdcon=10
proftpd_authserverip=
http_redirect_enable=0
pci/1/1/maxp5ga1=60,90,90,90
os_date=Oct 27 2014
filter_web_host11=
wl0_dfs_preism=60
openvpn_adv=0
pci/1/1/maxp5ga2=60,90,90,90
sb/1/regrev=0
filter_web_host12=
cron_enable=1
wl0_wds7_enable=0
svqos_port2prio=10
eth1_ipaddr=0.0.0.0
sb/1/ag0=0
filter_web_host13=
http_lanport=80
wl0_wme_txp_bk=7 3 4 2 0
olsrd_lqfisheye=1
sb/1/ag1=0
filter_mac_grp1=
filter_web_host14=
wl_plcphdr=long
wl_wme_sta_vo=3 7 2 3264 1504 off
openvpncl_proto=udp
usb_mntpoint=mnt
sb/1/ag2=0
filter_mac_grp2=
ppp_redialperiod=30
ppp_service=
wl_macmode=disabled
port1vlans=1
openvpn_config=
oet6_pt=0
wan_hwname=
wan_domain=
filter_mac_grp3=
wl_wme_ap_bk=15 1023 7 0 0 off
eth7_ipaddr=0.0.0.0
oet8_comp=0
oet10_pt=0
lan_lease=86400
wan_netmask=
filter_mac_grp4=
wl0_web_filter=0
wl_phytype=g
wl0_key1=
wl0_wds6_hwaddr=
radiooff_button=0
oet9_bridged=1
filter_mac_grp5=
pppoe_static_ip=
wl0_vlan_prio_mode=off
wl_lazywds=0
wl0_key2=
chilli_macauth=0
oet7_id=1
wl0.2_hwaddr=02:90:4C:02:50:03
filter_mac_grp6=
wl0_key3=
wl_dfs_postism=60
ddns_wildcard_6=
wl0_txant=3
oet10_bridged=1
filter_mac_grp7=
wl0_key4=
ddns_wildcard_7=
chilli_radiusnasid=
pptpd_client_srvsubmsk=
pci/1/1/sb20in80and160lr5glpo=0x0
filter_client0=
filter_mac_grp8=
wl0_bridged=1
ddns_url=
wshaper_nopriohostdst=
pci/1/1/pa5ga0=0xff39,0x1a55,0xfcc7,0xff38,0x1a7f,0xfcc3,0xff33,0x1a66,0xfcc4,0xff36,0x1a7b,0xfcc2
filter_maclist=
filter_mac_grp9=
chilli_url=
openvpncl_lzo=adaptive
eth3_netmask=0.0.0.0
oet4_mssfix=0
pci/1/1/boardflags=0x10000000
pci/1/1/pdgain2g=4
pci/1/1/pa5ga1=0xff3a,0x1a0b,0xfcd3,0xff38,0x1a37,0xfccd,0xff37,0x1aa1,0xfcc0,0xff37,0x1a6f,0xfcc4
ppp_demand=0
wl0_wmf_mdata_sendup=0
pptp_get_ip=
pptp_pass=1
oet1_netmask=255.255.255.0
pci/1/1/pa5ga2=0xff3a,0x1a28,0xfccd,0xff38,0x1a2a,0xfcce,0xff35,0x1a93,0xfcc1,0xff38,0x1aab,0xfcbe
pci/2/1/macaddr=84:1B:5E:EE:2E:D0
ppp_keepalive=0
mtu_enable=0
wl0_br1_nat=0
wd_sslavailable=0
usb_runonmount=
vlan2hwname=et0
block_activex=0
hotss_customsplash=0
pci/1/1/tempoffset=255
wan_ifname2=vlan2
wl0_wds5_ipaddr=
wl0_hw_rxchain=3
pci/1/1/mcsbw1605glpo=0x0
http_passwd=bJz7PcC1rCRJQ
wl0_rxchain_pwrsave_enable=0
wl0.1_ipaddr=0.0.0.0
remote_mgt_https=0
sshd_forwarding=0
wl0_br1_enable=0
sb/1/extpagain2g=3
block_wan=1
wl0_wds10_ipaddr=
oet6_comp=0
samba3_advanced=0
lan_stp=0
wl0.3_netmask=0.0.0.0
openvpncl_remoteport=1194
oet1_en=0
wl0.3_akm=disabled
wl0.3_radius_ipaddr=
wl0_wme_ap_vi=7 15 1 6016 3008 off
eth7_netmask=0.0.0.0
wl0_bss_maxassoc=128
pci/1/1/sb20in80and160lr5ghpo=0x0
router_style=elegant
wl_mode=ap
wl0.1_radius_key=
skip_amd_check=0
openvpncl_mtu=1400
oet5_netmask=255.255.255.0
pppd_pppifname=
forward_spec=
openvpn_cipher=bf-cbc
wl0_closed=0
wl0_rate=0
wl0_plcphdr=long
wl0.3_wpa_psk=
l2tp_server_name=
openvpn_tlscip=0
xtalfreq=20000
wl0_turbo_qam=1
wl0_macmode=disabled
wl0_wds4_netmask=
schedule_enable=0
oet5_pt=0
pptpd_client_srvmru=1436
wl0_radioids=BCM2056
sb/1/stbcpo=0x0
pptpd_radius=0
svqos_port1bw=FULL
wl0_wme_ap_vo=3 7 1 3264 1504 off
pci/1/1/boardvendor=0x14e4
wl0_phytype=n
block_snmp=1
wl_wme_txp_vi=7 3 4 2 0
pppoeserver_enabled=0
pci/1/1/mcsbw1605ghpo=0x0
filter_tod_buf1=
wl0_lazywds=0
dr_wan_rx=0
NC_RouteOnly=0
oet4_ipaddr=1.2.3.4
oet6_id=1
filter_tod_buf2=
block_proxy=0
wds1.10=
openvpncl_mssfix=0
oet4_shaper=0
oet10_id=1
oet10_fragment=0
olsrd_lqdijkstramin=0
pci/1/1/sb40and80lr5glpo=0x0
filter_tod_buf3=
wds1.11=
snmpd_syslocation=Unknown
rflow_port=2055
NC_GatewayPort=5280
oet9_netmask=255.255.255.0
upnp_ssdp_interval=60
filter_tod_buf4=
pptpd_rip=
chilli_pass=
wds1.12=
qos_type=0
oet4_comp=0
proftpd_enable=0
sb/1/aa2g=3
sb/1/bwduppo=0x0
filter_tod_buf5=
wds1.13=
oet10_netmask=255.255.255.0
sb/1/txchain=3
filter_tod_buf6=
wl0_netmask=0.0.0.0
wl0_afterburner=off
dr_lan_tx=0
wds1.14=
wl_wme_txp_vo=7 3 4 2 0
openvpn_crl=
upnpcas=0
lan_hwaddr=06:40:F5:96:F5:6B
filter_tod10=
filter_tod_buf7=
wl0_antdiv=3
apwatchdog_interval=15
wl0_wds8_netmask=
wds1.15=
wol_macs=
NC_SplashURLTimeout=21600
openvpncl_tuntap=tun
pci/1/1/subband5gver=0x4
wan_dns=
filter_tod_buf8=
wl0.1_auth_mode=disabled
wds1.16=
radio1_timer_enable=0
pci/1/1/boardnum=21059
filter_tod_buf9=
oet8_rem=192.168.90.1
samba3_pub=0
radius_common=DD-WRT FreeRadius Certificate
pci/1/1/measpower=0x7f
pci/1/1/dot11agduplrpo=0x0
wl0.1_akm=disabled
wl_shortslot=auto
wl_ssid=dd-wrt
wl_dtim=1
wl0_wds8_desc=
ipv6_enable0=0
ip_conntrack_max=4096
pci/1/1/sromrev=11
wl0.2_crypto=off
wl0_wpa_psk=
dhcpd_usenvram=0
log_dropped=0
forward_entries=0
wait_time=5
wl0_wds2_enable=0
pci/1/1/rxgainerr2g=0xffff
pci/1/1/sb40and80lr5ghpo=0x0
ppp_mppe=
pptpd_radport=1812
openvpncl_auth=md5
openvpn_crt=
radius_port=1812
pci/1/1/venid=0x14e4
wl0_amsdu=auto
daylight_time=3
wl0.2_auth=0
wl_passphrase=
macupd_ip=0.0.0.0
dns_dnsmasq=1
usb_printer=0
wl0_country_rev=0
dhcp_wins=wan
wl0_wds9_if=
eth2_ipaddr=0.0.0.0
oet2_comp=0
wl0_mbss=1
os_server=
filter_tod_buf10=
hotss_uamenable=0
wl0_wds8_enable=0
wl0_wds1_hwaddr=
upgrade_delay=300
eth0_bridged=1
pci/1/1/sb20in80and160hr5glpo=0x0
pci/1/1/sb20in40hrpo=0x0
pppoe_static=0
fon_usernames=0
oet4_pt=0
pci/1/1/ofdmlrbw202gpo=0
wan_proto=dhcp
wl0_wmf_igmpq_filter=0
wl_amsdu=auto
port_swap=0
hb_server_domain=
remote_mgt_ssh=0
wd_timeout=5
hotss_remotekey=
usb_usb2=0
pppoeserver_mru=1492
olsrd_lqdijkstramax=5.0
pci/1/1/mcsbw205gmpo=3999678464
wl0_unit=0
ospfd_conf=
mmc_enable=0
eth8_ipaddr=0.0.0.0
oet5_id=1
wl0_wds7_hwaddr=
wds0.10=
wshaper_noprioportsrc=
wl_hwaddr=
ddns_cache=
wl0_txpwr=71
wl0_wds6_desc=
wds0.11=
NC_IncludePorts=
wl0.3_hwaddr=02:90:4C:02:50:00
pci/1/1/boardrev=0x1303
wds0.12=
enable_jffs2=0
pptpd_client_srvpass=
pci/1/1/sb20in40hrrpo=0
static_route_name=
wds0.13=
oet6_rem=192.168.90.1
pci/1/1/dot11agofdmhrbw202gpo=0
wds0.14=
eth4_bridged=1
oet5_mssfix=0
pci/1/1/rxgains2gtrelnabypa0=0
pci/1/1/mcslr5glpo=0x0
wl0_nmode=-1
wl0_wmf_ucast_upnp=1
chilli_802.1Xauth=0
wds0.15=
openvpn_cl2cl=1
oet2_bridged=1
pci/1/1/rxgains2gtrelnabypa1=0
wl_net_mode=mixed
wl_active_mac=
ntp_enable=1
wds0.16=
pci/1/1/rxgains2gtrelnabypa2=0
pci/1/1/sb20in80and160hr5ghpo=0x0
wl_rifs_advert=auto
pci/1/1/tempsense_slope=0xff
remote_ip=0.0.0.0 0
radius_locality=none
wl1_country_rev=0
forward_port=
ddns_custom_5=
wl0_wds6_ipaddr=
pppoeserver_sharedkey_backup=
sys_enable_jffs2=0
smtp_redirect_enable=0
NC_HomePage=http://www.dd-wrt.com
wl0.2_ipaddr=0.0.0.0
wshaper_dev=WAN
pci/1/1/maxp2ga0=76
limit_pptp=0
wd_hostname=
olsrd_redundancy=2
pci/1/1/maxp2ga1=76
wl_rxstreams=0
eth8_bridged=1
squid_watchdog_interval_sec=120
pci/1/1/epagain5g=0
pci/1/1/maxp2ga2=76
filter_mac_grp10=
wl0_wds=
wl0_wds4_desc=
wl0_wds8_ospf=
snmpd_sysname=dd-wrt
oet6_bridged=1
generate_key=0
wanup=0
ppp_static_ip=
wl_rate=0
ddns_dyndnstype_6=
wl0_wds8_if=
pptp_server_name=
pci/1/1/sb40and80hr5glpo=0x0
pci/1/1/mcslr5ghpo=0x0
log_level=0
block_java=0
telnetd_enable=1
ct_modules=
ntp_server=
wl0_reg_mode=off
hs_urls=
static_leasenum=0
oet3_pt=0
wan_hwaddr=
openvpn_ccddef=
pci/1/1/boardtype=0x621
NC_GatewayName=DD-WRT
eth0_netmask=0.0.0.0
lan_ifnames=vlan1 eth1 eth2
wd_httpport=80
oet4_rem=192.168.90.1
oet4_id=1
pppoe_ifname=
wl_macmode1=disabled
sshd_dss_host_key=
remote_mgt_telnet=0
eth10_ipaddr=0.0.0.0
clone_wan_mac=0
wl0_auth=0
wl0_radius_port=1812
snmpd_enable=0
wl0_wme=on
wd_iface=
oet5_ipaddr=1.2.3.4
oet5_shaper=0
pppoeradius_enabled=0
radius_email=[email protected]
smtp_source_network=0.0.0.0
openvpncl_adv=0
openvpncl_mask=
wl0_rxchain=3
pci/1/1/pa2ga0=0xfe72,0x14c0,0xfac7
wl0_radius_ipaddr=
pptpd_conn=64
sshd_port=22
openvpn_mssfix=0
wd_gwid=default
pci/1/1/pa2ga1=0xfe80,0x1472,0xfabc
wan_default=vlan2
pppoe_service=
cron_jobs=
wshaper_noprioportdst=
pci/1/1/boardflags2=0x300000
pci/1/1/pa2ga2=0xfe82,0x14bf,0xfad9
svqos_macs=
wl0_wme_sta_vi=7 15 2 6016 3008 off
pci/1/1/boardflags3=0x300030
pci/1/1/sb40and80hr5ghpo=0x0
wl0_wds2_desc=
wl0_wds6_ospf=
openvpn_gateway=0.0.0.0
wl0.3_wpa_gtk_rekey=3600
eth4_netmask=0.0.0.0
schedule_weekdays=00
openvpn_tuntap=tun
oet2_netmask=255.255.255.0
squid_watchdog_enable=0
pci/1/1/aga0=71
sb/1/leddc=0xFFFF
wan_ifnames=vlan2
pci/1/1/aga1=133
remote_management=0
pppoeserver_deflate=0
pci/1/1/aga2=133
wl_crypto=off
wl_rateset=default
block_loopback=0
svqos_port4bw=FULL
hs_enable=
schedule_time=3600
NC_ExcludePorts=25
wl0_wme_sta_vo=3 7 2 3264 1504 off
radio0_timer_enable=0
oet10_rem=192.168.90.1
wl0.3_crypto=off
wl0_wds1_netmask=
nstxd_enable=0
proftpd_dir=mnt
wl0.2_key=1
wl0_wds3_enable=0
http_method=post
wl_wep_bit=64
chilli_net=192.168.182.0/24
svqos_svcs=
wifi_bonding=0
pci/1/1/measpower1=0x7f
wl0_wds7_if=
hs_exempt=
wd_password=
eth8_netmask=0.0.0.0
samba3_enable=0
pci/1/1/measpower2=0x7f
clkfreq=480,240,120
os_name=linux
upnp_internet_dis=0
lan_proto=dhcp
filter_port_grp1=
chilli_uamsecret=
oet2_rem=192.168.90.1
oet6_netmask=255.255.255.0
pppoeserver_chapsnum=0
pptpd_client_srvmtu=1436
vlan1hwname=et0
filter_port_grp2=
wl0_wds9_enable=0
wl0_maxassoc=128
eth3_ipaddr=0.0.0.0
oet2_pt=0
filter_port_grp3=
filter_port_grp10=
ddns_passwd_2=
wl0_wds2_hwaddr=
filter_port_grp4=
wl0.3_ssid=
wl_unit=0
dr_wan_tx=0
ddns_passwd_3=
wl0_wds4_ospf=
clean_jffs2=0
trigger_entries=0
openvpn_auth=md5
filter_port_grp5=
wl0_phytypes=n
wl0_max_unauth_users=0
ddns_passwd_4=
wol_enable=0
oet3_id=1
wl0_wep=disabled
filter_port_grp6=
wl0_frag=2346
wl_nmode_protection=auto
ddns_passwd_5=
wl0_wds5_netmask=
eth9_ipaddr=0.0.0.0
filter_port_grp7=
wl0_txbf_bfe_cap=1
wl0.1_closed=0
ddns_username=
ddns_passwd_6=
syslogd_enable=0
maskmac=1
filter_port_grp8=
pppoe_passwd=
ddns_passwd=
ddns_passwd_7=
wl0_wds8_hwaddr=
filter_port_grp9=
wl0_nbw=20
wl0_distance=2000
block_ident=1
ddns_passwd_8=
chilli_macpasswd=password
default_downlevel=100000
sdram_config=0x0104
log_enable=0
ppp_ac=
hs_image=
dhcpfwd_enable=0
auth_dnsmasq=1
wl0_btc_mode=0
l2tp_wan_gateway=0.0.0.0
filter_web_url10=
wl0_wds10_if=
sip_domain=192.168.1.1
filter_web_url11=
dmz_ipaddr=0
wl0_wds1_ipaddr=
oet6_mssfix=0
filter_web_url12=
wl_wds=
wl0.3_key1=
security_mode_last=
rc_startup=
sshd_passwd_auth=1
schedule_hours=0
openvpn_switch=0
pptpd_client_enable=0
pci/1/1/rxgains5gtrelnabypa0=0
filter_web_url13=
wl0.3_key2=
wl0.1_radius_ipaddr=
ddns_hostname_2=
sshd_enable=0
wl0_wds9_netmask=
wol_interval=86400
br1_mcast=0
usb_uhci=0
proftpd_wan=0
pci/1/1/rxgains5gtrelnabypa1=0
filter_web_url14=
wl0.3_key3=
ddns_hostname_3=
pci/1/1/rxgains5gtrelnabypa2=0
filter_web_url15=
wl0.3_key4=
ddns_hostname_4=
radiooff_boot_off=0
pppoeserver_clcount=64
pci/1/1/rxgains2gelnagaina0=0
wl0_ampdu_rr_rtylimit_tid=2 2 2 2 2 2 2 2
wl0.1_ssid=
wl0_rateset=default
ddns_hostname_5=
wl0_wds7_ipaddr=
wl0_wds2_ospf=
trunking=0
pci/1/1/rxgains2gelnagaina1=0
pci/1/1/txchain=3
ddns_hostname_6=
pppoeserver_lzs=0
pci/1/1/pdgain5g=4
pci/1/1/rxgains2gelnagaina2=0
wl0.3_ipaddr=0.0.0.0
ddns_hostname_7=
hotss_loginonsplash=0
macupd_port=2056
wl0_wme_apsd=on
pptpd_client_srvuser=DOMAIN\\Username
sb/1/ccode=0
ddns_hostname_8=
pptpd_acctport=1813
wl0_wme_txp_vi=7 3 4 2 0
pppoeserver_encryption=0
pppoe_idletime=5
wl_radauth=0
wl0_wds6_if=
wl_wme=on
pci/1/1/aa2g=0
pci/1/1/antswitch=0
oet9_en=0
pptpd_client_nat=1
pci/1/1/sar2g=18
lan_ifname=br0
wan_primary=1
wl_wme_ap_vi=7 15 1 6016 3008 off
fullswitch=0
openvpn_tlsauth=
oet1_pt=0
filter_services=
pppoeserver_mtu=1492
olsrd_smartgw=0
wandevs=et0
wl0_txbf_bfr_cap=1
pptp_extraoptions=
openvpn_onwan=0
overclocking=480
sb/1/cck2gpo=0x0
dhcp_domain=wan
wl0.1_key1=
wl0_radius_override=1
pptp_reorder=0
wl0_wme_txp_vo=7 3 4 2 0
eth1_bridged=1
oet2_id=1
pci/1/1/noiselvl2ga0=31
wl_auth=0
wl0.1_key2=
port4vlans=1
radius_country=DE
pci/1/1/temps_hysteresis=15
pci/1/1/noiselvl2ga1=31
wl0.1_key3=
wl_wep_last=
samba_mount=0
vlans=0
fon_userlist=
pci/1/1/noiselvl2ga2=31
wan_dial=0
wl0.1_key4=
wan_gateway_buf=0.0.0.0
wl_wme_ap_vo=3 7 1 3264 1504 off
openvpncl_bridge=0
oet6_ipaddr=1.2.3.4
pci/1/1/mcsbw205glpo=0x55555555
wan_vdsl=0
block_cookie=0
resetbutton_enable=1
oet6_shaper=0
warn_connlimit=500
ezc_enable=1
wl_frameburst=off
rc_firewall=
chilli_dns1=0.0.0.0
olsrd_hysteresis=0
transmission_enable=0
wl0_nmode_protection=auto
NC_enable=0
wd_maclist=
wl0_br1_ipaddr=0.0.0.0
pci/1/1/tworangetssi2g=0
wl0.1_bridged=1
eth5_bridged=1
pci/1/1/temps_period=15
pci/1/1/dot11agduphrpo=0x0
wan_ipaddr=
filter_web_url1=
dhcp_num=50
wl0.2_radius_key=
svqos_port3prio=10
smtp_redirect_destination=0.0.0.0
filter_web_url2=
openvpn_mask=0.0.0.0
openvpn_proxy=0
oet3_bridged=1
radius_enabled=0
filter_web_url3=
reconnect_hours=0
zabbix_enable=0
pci/1/1/mcsbw805gmpo=3999678464
filter_web_url4=
wl0_rts=2347
tcp_congestion_control=vegas
filter_web_url5=
zebra_conf=
ospfd_copt=0
openvpn_tunmask=0.0.0.0
wd_sslport=443
radius_organisation=DD-WRT
pci/1/1/cckbw20ul2gpo=0
sb/1/devid=0x4329
sb/1/bw40po=0x0
wan_wins=0.0.0.0
filter_web_url6=
wl_ifname=
port2vlans=1
fon_enable=0
pci/1/1/mcsbw205ghpo=0x11110000
filter_web_url7=
http_enable=1
wl_ampdu_rtylimit_tid=5 5 5 5 5 5 5 5
wl_wep=disabled
ntp_mode=auto
ipv6_enable=0
wl0_wds4_enable=0
wds1.1=
snmpd_syscontact=root
openvpn_port=1194
oet9_comp=0
wl0_hw_txchain=3
filter_web_url8=
l2tp_pass=1
wl0_radauth=0
wl0_wds5_if=
wds1.2=
pppoeserver_acctserverport_backup=1813
os_version=6.37.14.86 (r456083)
filter_web_url9=
pppoe_username=
wl0.2_auth_mode=disabled
ddns_dyndnstype=
wds1.3=
svqos_ips=
eth9_bridged=1
oet8_en=0
wl_gmode_protection=auto
l2tp_use_dhcp=1
wds1.4=
oet7_bridged=1
wl0_wpa_gtk_rekey=3600
sshd_rsa_host_key=
wds1.5=
eth4_ipaddr=0.0.0.0
ppp_get_srv=
wl0_sta_retry_time=5
mac_clone_enable=0
wds1.6=
pci/1/1/phycal_tempdelta=255
wl_frag=2346
wl0_wds3_hwaddr=
wds1.7=
oet1_id=1
pci/1/1/rxgainerr5g=0xffff,0xffff,0xffff,0xffff
wl_rx_amsdu_in_ampdu=auto
wl0_key=1
wl_wep_gen=
wan_mtu=1500
l2tp_req_chap=yes
wds1.8=
pci/1/1/noiselvl5gua0=31
wds1.9=
pppoerelay_enable=0
openvpncl_nat=0
openvpn_key=
eth1_netmask=0.0.0.0
pci/1/1/noiselvl5gua1=31
filter_macmode=deny
pptpd_mru=1436
pci/1/1/noiselvl5gua2=31
wl0.2_closed=0
wl0_wds9_hwaddr=
wd_httpdname=WiFiDog
oet1_mssfix=0
et0phyaddr=30
console_loglevel=7
pptp_wan_gateway=0.0.0.0
ppp_compression=0
svqos_port1prio=10
time_zone=+01
dnsmasq_options=
sshd_wanport=22
port0vlans=2
NC_LoginTimeout=86400
oet7_comp=0
wan_get_domain=
radius_state=Saxony
wl_cal_period=0
reconnect_minutes=0
pci/1/1/papdcap2g=0
wl0_wds2_ipaddr=
oet7_mssfix=0
ttraff_enable=1
proftpd_acctserverport=1813
wan_ifname=vlan2
wl0.1_netmask=0.0.0.0
l2tp_req_auth=yes
upnp_max_age=180
radvd_enable=0
sshd_authorized_keys=
wl_wme_sta_be=15 1023 3 0 0 off
eth5_netmask=0.0.0.0
squid_proxy_server_port=3128
sb/1/pdetrange2g=5
wl_radioids=
hotss_customuam=
oet3_netmask=255.255.255.0
pci/1/1/rxgains5gelnagaina0=3
wan_hostname=
wl0_dfs_postism=60
gozila_action=0
pci/1/1/rxgains5gelnagaina1=3
wl_corerev=
wl0_radio=1
wl0_wds8_ipaddr=
DD_BOARD=Netgear R6200
pci/1/1/femctrl=3
pci/1/1/rxgains5gelnagaina2=3
wl0_nbw_cap=1
wl0.1_wpa_psk=
info_passwd=0
zebra_enable=1
sv_restore_defaults=0
wl0_wds2_netmask=
wl0_wds4_if=
svqos_port3bw=FULL
pppoeserver_authserverip_backup=
wl0_bcn=100
manual_boot_nv=0
wl_wme_sta_bk=15 1023 7 0 0 off
oet7_en=0
oet10_comp=0
pppoeserver_acctserverport=1813
proftpd_port=21
pci/1/1/tssiposslope2g=1
pptpd_auth=
snmpd_conf=See http://www.net-snmp.org for expert snmpd.conf options
openvpncl_route=
olsrd_gateway=0
dtag_vlan8=0
filter_tod1=
ppp_static=0
wl0_hwaddr=00:90:4C:02:50:01
wl_radio=1
wl_afterburner=off
block_multicast=1
macupd_interval=10
radio0_on_time=111111111111111111111111
pci/1/1/ccode=DE
filter_tod2=
dyn_default=0
log_rejected=0
eth9_netmask=0.0.0.0
oet5_comp=0
olsrd_pollsize=0.1
filter_tod3=
wl0_ampdu_rtylimit_tid=5 5 5 5 5 5 5 5
oet1_ipaddr=1.2.3.4
oet7_netmask=255.255.255.0
proftpd_sharedkey=
sb/1/tssipos2g=1
ezc_version=2
filter_tod4=
oet1_shaper=0
filter_tod5=
wl_stbc_rx=1
wl0_gmode_protection=auto
wk_mode=gateway
ddns_passwd_buf=
dnsmasq_no_dns_rebind=1
oet9_rem=192.168.90.1
pci/1/1/noiselvl5gma0=31
pci/1/1/rxgains5gtrisoa0=1
filter_tod6=
wl0.1_wpa_gtk_rekey=3600
wl0.2_akm=disabled
rc_shutdown=
nstx_log=0
pci/1/1/noiselvl5gma1=31
pci/1/1/rxgains5gtrisoa1=1
filter_tod7=
wl0_obss_coex=0
wl0_wds6_netmask=
NC_GatewayMode=Open
pci/1/1/noiselvl5gma2=31
pci/1/1/rxgains5gtrisoa2=1
sdram_init=0x0000
filter_tod8=
wl_rts=2347
wl0_radmacpassword=0
oet7_ipaddr=1.2.3.4
pci/1/1/mcsbw405gmpo=3999678464
filter_tod9=
wl0_wds9_desc=
oet7_shaper=0
sb/1/antswctl2g=2
lan_wins=
wl_ap_isolate=0
lan_hwnames=
wl_mac_list=
dhcpd_options=
ip_conntrack_udp_timeouts=120
NC_IdleTimeout=0
dhcp_dnsmasq=1
wd_path=/wifidog
pppoeserver_sharedkey=
dhcpd_usejffs=0
wl1_country_code=US
pppoe_demand=0
wds_watchdog_enable=0
wl_wme_no_ack=off
static_leases=
openvpncl_sec=1
wl0.3_auth=0
local_dns=0
wd_auth=0
radius_passphrase=changeme
filter_dport_grp10=
wl0_radius_key=
wl0_wds10_desc=
oet3_comp=0
ddns_username_buf=
wl0_wds10_netmask=
wl0_wme_ap_be=15 63 3 0 0 off
wl0_corerev=17
wl0_nmcsidx=-1
wd_enable=0
proftpd_rad=0
wl0_lazy_wds=
refresh_time=3
openvpncl_certtype=0
dlna_thumb=0
pci/1/1/regrev=0
wl0_channel=6
wl0_wds3_if=
usb_ses_umount=0
sb/1/ledbh0=11
pptp_encrypt=0
wl0_wds5_enable=0
oet6_en=0
usb_enable=0
sb/1/maxp2ga0=0x5e
sb/1/ledbh1=11
wl0_wmf_ucigmp_query=0
ddns_wan_ip=1
NC_ForcedRedirect=0
oet10_en=0
pci/2/1/regrev=0
pci/1/1/tempsense_option=0x3
pci/1/1/devid=0x43a0
sb/1/maxp2ga1=0x5E
sb/1/ledbh2=11
upnp_enable=0
dr_setting=0
wl0_wds10_enable=0
wl0_wds7_desc=
schedule_hour_time=1
wl0_wme_ap_bk=15 1023 7 0 0 off
br0_mcast=0
oet7_rem=192.168.90.1
pppoeserver_interface=br0
sb/1/ledbh3=11
hs_redirect=
wl_wme_txp_be=7 3 4 2 0
openvpn_startip=0.0.0.0
openvpn_ca=
nstx_ipenable=0
http_redirect_destination=0.0.0.0
pci/1/1/tempthresh=255
eth5_ipaddr=0.0.0.0
pppoeserver_sessionlimit=0
pci/1/1/mcsbw402gpo=0
pci/1/1/macaddr=84:1B:5E:EE:2E:CF
sb/1/cddpo=0x0
wl0_rx_amsdu_in_ampdu=auto
pptpd_lip=
wl0_wds4_hwaddr=
wol_hostname=
dhcpc_vendorclass=
openvpn_fragment=
proftpd_anon=0
sb/1/opo=0x0
filter_rule10=
wl0_stbc_rx=1
openvpn_endip=0.0.0.0
openvpn_dhcpbl=0
wl0.1_auth=0
wl_dfs_preism=60
rflow_if=br0
forwardspec_entries=0
openvpncl_pkcs12=
nstx_ip=0.0.0.0
eth2_bridged=1
sb/1/rxchain=3
wan_dualaccess=0
ppp_mlppp=0
oet1_comp=0
pppoeserver_lcpechoint=5
wl0_auth_mode=disabled
def_whwaddr=00:00:00:00:00:00
NC_AllowedWebHosts=
wl_wme_txp_bk=7 3 4 2 0
pppoeserver_authserverport_backup=1812
wl0.3_closed=0
status_auth=1
dhcpc_requestip=
oet2_mssfix=0
autofw_port0=
boardnum=01
wl0_crypto=off
language=english
pppoeserver_pool=192.168.1.100
warn_enabled=0
wl0_txchain=3
sb/1/antswitch=0
def_hwaddr=00:00:00:00:00:00
hwmon_temp_max=60
olsrd_lqlevel=2
proftpd_writeen=off
wl_bcn=100
oet8_mssfix=0
ptoken=0
wl0_itxbf=0
wl0.2_bridged=1
wl_reg_mode=off
wl_wep_buf=
macupd_enable=0
hotss_operatorid=
wl0_wds3_ipaddr=
wl0_wds5_desc=
wl0_wds9_ospf=
openvpn_net=0.0.0.0
mmc_enable0=0
wd_username=
eth6_bridged=1
oet10_mssfix=0
upnp_config=1
limit_telnet=0
rflow_ip=0.0.0.0
oet4_bridged=1
pci/1/1/mcsbw202gpo=0
filter_dport_grp1=
wl0.2_radius_ipaddr=
filter_dport_grp2=
rc_custom=
wl0_wds9_ipaddr=
default_uplevel=100000
pptpd_client_mru=1436
oet1_fragment=0
oet5_rem=192.168.90.1
size: 26935 bytes (38601 left)
Sayan Mukherjee
Andy Lee
Andy Lee's picture
Hi Sayan.
Hi Sayan.
Sayan Mukherjee
Andy Lee
Andy Lee's picture
Sayan Mukherjee
Okay...
Okay...
Andy Lee
Andy Lee's picture
NVRAM SHOW:[/code
NVRAM SHOW:
[/code]
Init Arena
Init Devs.
Startup canceled
CFE> ^C
CFE> nvram show
sb/1/elna2g=3
boardrev=0x1101
boot_wait=off
watchdog=3000
et0mdcport=0
reset_gpio=3
vlan2ports=4 8u
sb/1/triso2g=4
sb/1/sromrev=8
gpio5=robo_reset
sromrev=8
boardtype=0xF52C
sb/1/regrev=0
sb/1/ag0=0
sb/1/ag1=0
sb/1/ag2=0
vlan2hwname=et0
sb/1/extpagain2g=3
xtalfreq=20000
sb/1/stbcpo=0x1111
sb/1/aa2g=3
sb/1/bwduppo=0
sb/1/txchain=3
boardmfg=NETGEAR
cfe_version=v1.0.1
wait_time=3
sb/1/leddc=0xFFFF
clkfreq=480,240,120
vlan1hwname=et0
sdram_config=0x0104
sb/1/ccode=0
wandevs=et0
sb/1/cck2gpo=0x1111
sb/1/devid=0x4329
sb/1/bw40po=0x0000
et0phyaddr=30
sb/1/pdetrange2g=5
sb/1/tssipos2g=1
sdram_init=0x0000
sb/1/antswctl2g=2
sb/1/ledbh0=11
sb/1/maxp2ga0=0x56
sb/1/ledbh1=11
sb/1/maxp2ga1=0x56
sb/1/ledbh2=11
sb/1/ledbh3=11
sb/1/cddpo=0x1111
sb/1/rxchain=3
boardnum=01
sb/1/antswitch=0
[code]
[/code]
CFE> go
Checksum mismatch:
Entry at 0x80001000
Zone ranges:
  HighMem  empty
NR_IRQS:128
PCI: Reset RC
PCI: no core
PCI: scanning bus 0
brd: module loaded
nvram size: 65536
partition size = 0
netem: version 1.3
u32 classifier
    Actions configured
ip_set: protocol 6
TCP: bic registered
TCP: lp registered
found nvram
start service
starting hotplug
done
boardnum 01
boardtype 0xF52C
boardrev 0x1101
No such device
loading et
loading switch-core
loading switch-robo
[USB] checking...
nbw = 20
channel 6, val 20
0, 1000, 0, 6
spec 1006
wl: Unsupported
Bad argument `MARK'
[code]
Sayan Mukherjee
Andy Lee
Andy Lee's picture
ses_script=
filter_dport_grp3=
wl_mac_deny=
wl0_wds2_if=
olsrd_coverage=7
filter_dport_grp4=
wl0_wds10_ospf=
oet5_en=0
wan_unit=0
filter_dport_grp5=
filter=on
oet2_fragment=0
sb/1/elna2g=3
sv_localdns=0.0.0.0
filter_dport_grp6=
wl0_net_mode=mixed
wds0.1=
NC_Verbosity=2
nvram_ver=3
filter_dport_grp7=
chilli_interface=
wds0.2=
altdns1=
openvpncl_ip=
filter_dport_grp8=
wl_txstreams=0
wl0_frameburst=off
wds0.3=
altdns2=
openvpncl_client=
oet3_fragment=0
pppoeserver_idle=0
filter_dport_grp9=
wl0_txbf=0
wds0.4=
altdns3=
oet8_bridged=1
log_ipaddr=0
ddns_username_2=
pptpd_mtu=1436
wds0.5=
zebra_log=0
oet2_ipaddr=1.2.3.4
oet9_pt=0
pci/1/1/mrrs=128
boardrev=0x1101
ddns_username_3=
chilli_enable=0
hotss_enable=0
wl0_wds3_desc=
wl0_wds7_ospf=
wds0.6=
NC_RenewTimeout=0
oet2_shaper=0
oet4_fragment=0
ppp_passwd=
ppp_idletime=5
ddns_username_4=
wds0.7=
pci/1/1/aa5g=3
ddns_username_5=
wds0.8=
zebra_copt=0
NC_SplashURL=
openvpncl_enable=0
pppoeserver_mppc=0
pci/1/1/sar5g=15
ddns_username_6=
wds0.9=
oet5_fragment=0
oet8_ipaddr=1.2.3.4
ddns_username_7=
openvpn_dupcn=0
oet8_shaper=0
qos_done=0
wl0_leddc=0x640000
wl0.3_key=1
ddns_enable=0
ddns_username_8=
wl0_bw_cap=255
wl0_ipaddr=0.0.0.0
NC_MaxMissedARP=5
openvpn_mtu=1400
oet6_fragment=0
oet10_shaper=0
wl0_shortslot=auto
ddns_conf=
skip_intel_check=0
NC_MACWhiteList=
wan_get_dns=
wl0_akm=disabled
ddns_hostname_buf=
wl_maxassoc=128
boot_wait=on
watchdog=3000
syslogd_rem_ip=
openvpncl_key=
oet7_fragment=0
filter_web_host1=
wl_phytypes=
nas_enable=1
wl0_infra=1
filter_web_host2=
hotss_uamallowed=
wl0_country_code=DE
et0mdcport=0
fw_disable=0
filter_web_host3=
filter_web_host4=
pppoe_keepalive=0
router_name=DD-WRT
wl0_wds1_desc=
wl0_wds5_ospf=
wl0_wds1_if=
openvpn_dh=
oet8_fragment=0
auth_limit=180
filter_web_host5=
wshaper_enable=0
oet4_en=0
filter_web_host6=
https_enable=0
wl_distance=2000
ddns_wildcard=
l2tp_ref_pap=yes
wl0_wds6_enable=0
wd_url=
eth0_ipaddr=0.0.0.0
filter_web_host7=
wl_infra=1
wl0.2_wpa_psk=
apwatchdog_enable=0
oet9_fragment=0
dlna_enable=0
reset_gpio=3
ses_event=2
filter_web_host8=
l2tp_get_ip=
pptp_iptv=0
telnet_wanport=23
wl0_wds3_netmask=
svqos_port2bw=FULL
openvpncl_config=
usb_automnt=0
filter_web_host9=
dhcpfwd_ip=0.0.0.0
wl0_bcn_rotate=0
ppp_get_ac=
wl_stbc_tx=auto
pptp_server_ip=
pptpd_forcemppe=1
restore_defaults=0
ddns_time=
pptpd_bcrelay=0
eth6_ipaddr=0.0.0.0
oet8_pt=0
pppoeserver_chaps=
pci/2/1/ccode=US
vlan2ports=4 8
wl0_cal_period=0
hotss_locationid=
wl0_wds5_hwaddr=
pptp_use_dhcp=1
wl0_bandlist=b
wl0.1_key=1
wl0.3_radius_key=
wshaper_downlink=0
ppp_username=
wl0_atf=0
wl0_wds10_hwaddr=
pptpd_client_srvip=
oet9_id=1
wan_lease=86400
filter_port=
wl0_nctrlsb=lower
openvpn_pkcs12=
pci/1/1/_mrrs=128
sb/1/triso2g=4
ddns_enable_buf=
wl_wme_apsd=on
eth10_bridged=1
oet3_mssfix=0
olsrd_lqaging=0.1
sb/1/sromrev=8
filter_ip_grp1=
http_wanport=8080
wl0.2_ssid=
ddns_hostname=
wl0_wds7_netmask=
wl0_wds3_ospf=
dlna_cleandb=0
pci/1/1/agbg0=71
lan_gateway=0.0.0.0
filter_ip_grp2=
openvpn_redirgate=0
usb_ohci=0
pci/1/1/agbg1=71
wl0_ifname=eth0
filter_ip_grp3=
hwmon_temp_hyst=50
usb_storage=0
pci/1/1/agbg2=133
pci/1/1/epagain2g=0
lan_domain=
filter_ip_grp4=
dr_lan_rx=0
timer_interval=3600
filter_ip_grp5=
wl0_wds4_ipaddr=
oet9_mssfix=0
reconnect_enable=0
filter_ip_grp6=
hs_html=
log_accepted=0
openvpn_clcon=
filter_rule1=
filter_ip_grp7=
pppoe_ac=
wshaper_uplink=0
ses_button=0
filter_rule2=
filter_ip_grp8=
ipsec_pass=1
hb_server_ip=
gpio5=robo_reset
ses_enable=1
filter_rule3=
filter_ip_grp9=
rflow_enable=0
wl0_wds0_if=
expert_mode=1
filter_rule4=
wl0.2_key1=
schedule_minutes=0
oet3_en=0
pci/1/1/papdcap5g=0
filter_rule5=
wl0.2_key2=
port5vlans=1 2 16
filter_rule6=
filter_ip_grp10=
wl0.2_key3=
wl0_mrate=0
hotss_interface=
openvpncl_tlscip=0
wan_gateway=
filter_rule7=
wl0_mode=ap
wl0.2_key4=
wol_passwd=
filter_rule8=
dhcp_start=100
pptpd_radpass=
wl0_wds1_ospf=
openvpncl_fragment=
filter_rule9=
wl0_stbc_tx=auto
chilli_uamanydns=0
wl0_ap_isolate=0
pptpd_enable=0
oet7_pt=0
filter_services_1=
wl_mrate=0
chilli_uamallowed=
svqos_port4prio=10
openvpn_client=
oet3_ipaddr=1.2.3.4
sb/1/itt2ga0=0x20
ddns_force=10
l2tp_server_ip=
oet3_shaper=0
sb/1/itt2ga1=0x20
sromrev=8
dhcp_lease=1440
wl0_ampdu=auto
wl0_gmode=1
wl0_wme_no_ack=off
wd_interval=60
oet8_id=1
samba3_pubacl=1
remote_ip_any=1
wds_watchdog_ips=
openvpn_proto=udp
wd_extiface=
eth3_bridged=1
3gdata=
boardtype=0xF52C
limit_ssh=0
openvpn_enable=0
oet1_bridged=1
oet9_ipaddr=1.2.3.4
proftpd_passw=
is_default=1
wl_obss_coex=0
dnsmasq_enable=1
chilli_additional=
oet9_shaper=0
wl0_nband=0
wl_ampdu=auto
port3vlans=1
stats_server=
pci/1/1/rxchain=3
static_route=
wd_gwport=2060
need_commit=1
wl0_nreqd=0
NC_extifname=auto
sip_port=5060
openvpncl_ca=
wl0.3_bridged=1
wl0.1_crypto=off
radvd_conf=
openvpncl_tlsauth=
dmz_enable=0
wl0_wds1_enable=0
eth7_bridged=1
ttraff_iface=
wl0_ssid=dd-wrt
wl0_dtim=1
oet5_bridged=1
wifi_display=wl0
port_trigger=
oet2_en=0
filter_web_host10=
wd_httpdcon=10
os_date=Oct 27 2014
filter_web_host11=
wl0_dfs_preism=60
openvpn_adv=0
sb/1/regrev=0
filter_web_host12=
cron_enable=1
wl0_wds7_enable=0
svqos_port2prio=10
eth1_ipaddr=0.0.0.0
sb/1/ag0=0
filter_web_host13=
http_lanport=80
olsrd_lqfisheye=1
sb/1/ag1=0
filter_mac_grp1=
filter_web_host14=
wl_plcphdr=long
openvpncl_proto=udp
usb_mntpoint=mnt
sb/1/ag2=0
filter_mac_grp2=
ppp_redialperiod=30
ppp_service=
wl_macmode=disabled
port1vlans=1
openvpn_config=
oet6_pt=0
wan_hwname=
wan_domain=
filter_mac_grp3=
eth7_ipaddr=0.0.0.0
oet8_comp=0
oet10_pt=0
lan_lease=86400
wan_netmask=
filter_mac_grp4=
wl0_web_filter=0
wl_phytype=g
wl0_key1=
wl0_wds6_hwaddr=
radiooff_button=0
oet9_bridged=1
filter_mac_grp5=
pppoe_static_ip=
wl_lazywds=0
wl0_key2=
chilli_macauth=0
oet7_id=1
filter_mac_grp6=
wl0_key3=
wl_dfs_postism=60
ddns_wildcard_6=
wl0_txant=3
oet10_bridged=1
filter_mac_grp7=
wl0_key4=
ddns_wildcard_7=
chilli_radiusnasid=
filter_client0=
filter_mac_grp8=
wl0_bridged=1
ddns_url=
filter_maclist=
filter_mac_grp9=
chilli_url=
oet4_mssfix=0
pci/1/1/pdgain2g=4
ppp_demand=0
pptp_get_ip=
pptp_pass=1
ppp_keepalive=0
mtu_enable=0
wl0_br1_nat=0
wd_sslavailable=0
usb_runonmount=
vlan2hwname=et0
block_activex=0
wan_ifname2=vlan2
wl0_wds5_ipaddr=
wl0_hw_rxchain=3
remote_mgt_https=0
sshd_forwarding=0
wl0_br1_enable=0
sb/1/extpagain2g=3
block_wan=1
wl0_wds10_ipaddr=
oet6_comp=0
samba3_advanced=0
lan_stp=0
oet1_en=0
wl0.3_akm=disabled
wl_mode=ap
wl0.1_radius_key=
skip_amd_check=0
openvpncl_mtu=1400
pppd_pppifname=
forward_spec=
wl0_closed=0
wl0_rate=0
wl0_plcphdr=long
wl0.3_wpa_psk=
l2tp_server_name=
openvpn_tlscip=0
xtalfreq=20000
wl0_turbo_qam=1
wl0_wds4_netmask=
schedule_enable=0
oet5_pt=0
sb/1/stbcpo=0x0
pptpd_radius=0
svqos_port1bw=FULL
wl0_phytype=n
block_snmp=1
filter_tod_buf1=
wl0_lazywds=0
dr_wan_rx=0
NC_RouteOnly=0
oet4_ipaddr=1.2.3.4
oet6_id=1
filter_tod_buf2=
block_proxy=0
wds1.10=
openvpncl_mssfix=0
oet4_shaper=0
oet10_id=1
oet10_fragment=0
filter_tod_buf3=
wds1.11=
rflow_port=2055
NC_GatewayPort=5280
filter_tod_buf4=
pptpd_rip=
chilli_pass=
wds1.12=
qos_type=0
oet4_comp=0
proftpd_enable=0
sb/1/aa2g=3
sb/1/bwduppo=0x0
filter_tod_buf5=
wds1.13=
sb/1/txchain=3
filter_tod_buf6=
wl0_netmask=0.0.0.0
wl0_afterburner=off
dr_lan_tx=0
wds1.14=
openvpn_crl=
upnpcas=0
filter_tod10=
filter_tod_buf7=
wl0_antdiv=3
wl0_wds8_netmask=
wds1.15=
wol_macs=
wan_dns=
filter_tod_buf8=
wds1.16=
filter_tod_buf9=
samba3_pub=0
wl0.1_akm=disabled
wl_shortslot=auto
wl_ssid=dd-wrt
wl_dtim=1
wl0_wds8_desc=
ipv6_enable0=0
pci/1/1/sromrev=11
wl0.2_crypto=off
wl0_wpa_psk=
dhcpd_usenvram=0
log_dropped=0
forward_entries=0
wait_time=5
wl0_wds2_enable=0
ppp_mppe=
pptpd_radport=1812
openvpncl_auth=md5
openvpn_crt=
radius_port=1812
wl0_amsdu=auto
daylight_time=3
wl0.2_auth=0
wl_passphrase=
macupd_ip=0.0.0.0
dns_dnsmasq=1
usb_printer=0
wl0_country_rev=0
dhcp_wins=wan
wl0_wds9_if=
eth2_ipaddr=0.0.0.0
oet2_comp=0
wl0_mbss=1
os_server=
filter_tod_buf10=
hotss_uamenable=0
wl0_wds8_enable=0
wl0_wds1_hwaddr=
upgrade_delay=300
eth0_bridged=1
pppoe_static=0
fon_usernames=0
oet4_pt=0
wan_proto=dhcp
wl_amsdu=auto
port_swap=0
hb_server_domain=
remote_mgt_ssh=0
wd_timeout=5
hotss_remotekey=
usb_usb2=0
wl0_unit=0
ospfd_conf=
mmc_enable=0
eth8_ipaddr=0.0.0.0
oet5_id=1
wl0_wds7_hwaddr=
wds0.10=
wl_hwaddr=
ddns_cache=
wl0_txpwr=71
wl0_wds6_desc=
wds0.11=
NC_IncludePorts=
wds0.12=
enable_jffs2=0
static_route_name=
wds0.13=
wds0.14=
eth4_bridged=1
oet5_mssfix=0
wl0_nmode=-1
chilli_802.1Xauth=0
wds0.15=
openvpn_cl2cl=1
oet2_bridged=1
wl_net_mode=mixed
wl_active_mac=
ntp_enable=1
wds0.16=
wl_rifs_advert=auto
remote_ip=0.0.0.0 0
wl1_country_rev=0
forward_port=
ddns_custom_5=
wl0_wds6_ipaddr=
sys_enable_jffs2=0
wshaper_dev=WAN
pci/1/1/maxp2ga0=76
limit_pptp=0
wd_hostname=
olsrd_redundancy=2
pci/1/1/maxp2ga1=76
wl_rxstreams=0
eth8_bridged=1
pci/1/1/epagain5g=0
pci/1/1/maxp2ga2=76
filter_mac_grp10=
wl0_wds=
wl0_wds4_desc=
wl0_wds8_ospf=
oet6_bridged=1
generate_key=0
wanup=0
ppp_static_ip=
wl_rate=0
ddns_dyndnstype_6=
wl0_wds8_if=
pptp_server_name=
log_level=0
block_java=0
telnetd_enable=1
ct_modules=
ntp_server=
wl0_reg_mode=off
hs_urls=
static_leasenum=0
oet3_pt=0
wan_hwaddr=
openvpn_ccddef=
wd_httpport=80
oet4_id=1
pppoe_ifname=
sshd_dss_host_key=
remote_mgt_telnet=0
clone_wan_mac=0
wl0_auth=0
snmpd_enable=0
wl0_wme=on
wd_iface=
oet5_ipaddr=1.2.3.4
oet5_shaper=0
openvpncl_adv=0
openvpncl_mask=
wl0_rxchain=3
wl0_radius_ipaddr=
pptpd_conn=64
sshd_port=22
openvpn_mssfix=0
wd_gwid=default
wan_default=vlan2
pppoe_service=
cron_jobs=
svqos_macs=
wl0_wds2_desc=
wl0_wds6_ospf=
openvpn_tuntap=tun
pci/1/1/aga0=71
sb/1/leddc=0xFFFF
wan_ifnames=vlan2
pci/1/1/aga1=133
remote_management=0
pci/1/1/aga2=133
wl_crypto=off
wl_rateset=default
block_loopback=0
svqos_port4bw=FULL
hs_enable=
schedule_time=3600
NC_ExcludePorts=25
wl0.3_crypto=off
wl0_wds1_netmask=
nstxd_enable=0
proftpd_dir=mnt
wl0.2_key=1
wl0_wds3_enable=0
http_method=post
wl_wep_bit=64
svqos_svcs=
wifi_bonding=0
wl0_wds7_if=
hs_exempt=
wd_password=
samba3_enable=0
clkfreq=480,240,120
os_name=linux
upnp_internet_dis=0
lan_proto=dhcp
filter_port_grp1=
chilli_uamsecret=
vlan1hwname=et0
filter_port_grp2=
wl0_wds9_enable=0
wl0_maxassoc=128
eth3_ipaddr=0.0.0.0
oet2_pt=0
filter_port_grp3=
filter_port_grp10=
ddns_passwd_2=
wl0_wds2_hwaddr=
filter_port_grp4=
wl0.3_ssid=
wl_unit=0
dr_wan_tx=0
ddns_passwd_3=
wl0_wds4_ospf=
clean_jffs2=0
trigger_entries=0
openvpn_auth=md5
filter_port_grp5=
wl0_phytypes=n
ddns_passwd_4=
wol_enable=0
oet3_id=1
wl0_wep=disabled
filter_port_grp6=
wl0_frag=2346
ddns_passwd_5=
wl0_wds5_netmask=
eth9_ipaddr=0.0.0.0
filter_port_grp7=
wl0_txbf_bfe_cap=1
wl0.1_closed=0
ddns_username=
ddns_passwd_6=
syslogd_enable=0
maskmac=1
filter_port_grp8=
pppoe_passwd=
ddns_passwd=
ddns_passwd_7=
wl0_wds8_hwaddr=
filter_port_grp9=
wl0_nbw=20
wl0_distance=2000
block_ident=1
ddns_passwd_8=
sdram_config=0x0104
log_enable=0
ppp_ac=
hs_image=
dhcpfwd_enable=0
auth_dnsmasq=1
wl0_btc_mode=0
filter_web_url10=
wl0_wds10_if=
filter_web_url11=
dmz_ipaddr=0
wl0_wds1_ipaddr=
oet6_mssfix=0
filter_web_url12=
wl_wds=
wl0.3_key1=
security_mode_last=
rc_startup=
sshd_passwd_auth=1
schedule_hours=0
openvpn_switch=0
filter_web_url13=
wl0.3_key2=
ddns_hostname_2=
sshd_enable=0
wl0_wds9_netmask=
wol_interval=86400
br1_mcast=0
usb_uhci=0
proftpd_wan=0
filter_web_url14=
wl0.3_key3=
ddns_hostname_3=
filter_web_url15=
wl0.3_key4=
ddns_hostname_4=
radiooff_boot_off=0
wl0.1_ssid=
wl0_rateset=default
ddns_hostname_5=
wl0_wds7_ipaddr=
wl0_wds2_ospf=
trunking=0
pci/1/1/txchain=3
ddns_hostname_6=
pppoeserver_lzs=0
pci/1/1/pdgain5g=4
ddns_hostname_7=
macupd_port=2056
wl0_wme_apsd=on
sb/1/ccode=0
ddns_hostname_8=
pptpd_acctport=1813
pppoe_idletime=5
wl_radauth=0
wl0_wds6_if=
wl_wme=on
pci/1/1/aa2g=0
pci/1/1/antswitch=0
oet9_en=0
pptpd_client_nat=1
pci/1/1/sar2g=18
lan_ifname=br0
wan_primary=1
fullswitch=0
openvpn_tlsauth=
oet1_pt=0
filter_services=
olsrd_smartgw=0
wandevs=et0
wl0_txbf_bfr_cap=1
pptp_extraoptions=
openvpn_onwan=0
overclocking=480
sb/1/cck2gpo=0x0
dhcp_domain=wan
wl0.1_key1=
pptp_reorder=0
eth1_bridged=1
oet2_id=1
wl_auth=0
wl0.1_key2=
port4vlans=1
radius_country=DE
wl0.1_key3=
wl_wep_last=
samba_mount=0
vlans=0
fon_userlist=
wan_dial=0
wl0.1_key4=
openvpncl_bridge=0
oet6_ipaddr=1.2.3.4
wan_vdsl=0
block_cookie=0
oet6_shaper=0
warn_connlimit=500
ezc_enable=1
wl_frameburst=off
rc_firewall=
chilli_dns1=0.0.0.0
olsrd_hysteresis=0
NC_enable=0
wd_maclist=
wl0.1_bridged=1
eth5_bridged=1
wan_ipaddr=
filter_web_url1=
dhcp_num=50
wl0.2_radius_key=
svqos_port3prio=10
filter_web_url2=
openvpn_proxy=0
oet3_bridged=1
radius_enabled=0
filter_web_url3=
reconnect_hours=0
zabbix_enable=0
filter_web_url4=
wl0_rts=2347
filter_web_url5=
zebra_conf=
ospfd_copt=0
wd_sslport=443
sb/1/devid=0x4329
sb/1/bw40po=0x0
wan_wins=0.0.0.0
filter_web_url6=
wl_ifname=
port2vlans=1
fon_enable=0
filter_web_url7=
http_enable=1
wl_wep=disabled
ntp_mode=auto
ipv6_enable=0
wl0_wds4_enable=0
wds1.1=
openvpn_port=1194
oet9_comp=0
wl0_hw_txchain=3
filter_web_url8=
l2tp_pass=1
wl0_radauth=0
wl0_wds5_if=
wds1.2=
filter_web_url9=
pppoe_username=
ddns_dyndnstype=
wds1.3=
svqos_ips=
eth9_bridged=1
oet8_en=0
l2tp_use_dhcp=1
wds1.4=
oet7_bridged=1
sshd_rsa_host_key=
wds1.5=
eth4_ipaddr=0.0.0.0
ppp_get_srv=
mac_clone_enable=0
wds1.6=
wl_frag=2346
wl0_wds3_hwaddr=
wds1.7=
oet1_id=1
wl0_key=1
wl_wep_gen=
wan_mtu=1500
l2tp_req_chap=yes
wds1.8=
wds1.9=
pppoerelay_enable=0
openvpncl_nat=0
openvpn_key=
filter_macmode=deny
pptpd_mru=1436
wl0.2_closed=0
wl0_wds9_hwaddr=
oet1_mssfix=0
et0phyaddr=30
console_loglevel=7
ppp_compression=0
svqos_port1prio=10
time_zone=+01
dnsmasq_options=
sshd_wanport=22
port0vlans=2
oet7_comp=0
wan_get_domain=
radius_state=Saxony
wl_cal_period=0
reconnect_minutes=0
pci/1/1/papdcap2g=0
wl0_wds2_ipaddr=
oet7_mssfix=0
ttraff_enable=1
wan_ifname=vlan2
l2tp_req_auth=yes
upnp_max_age=180
radvd_enable=0
sb/1/pdetrange2g=5
wl_radioids=
hotss_customuam=
wan_hostname=
wl0_dfs_postism=60
gozila_action=0
wl_corerev=
wl0_radio=1
wl0_wds8_ipaddr=
pci/1/1/femctrl=3
wl0_nbw_cap=1
wl0.1_wpa_psk=
info_passwd=0
zebra_enable=1
wl0_wds2_netmask=
wl0_wds4_if=
svqos_port3bw=FULL
wl0_bcn=100
manual_boot_nv=0
oet7_en=0
oet10_comp=0
proftpd_port=21
pptpd_auth=
openvpncl_route=
olsrd_gateway=0
dtag_vlan8=0
filter_tod1=
ppp_static=0
wl_radio=1
wl_afterburner=off
block_multicast=1
macupd_interval=10
pci/1/1/ccode=DE
filter_tod2=
dyn_default=0
log_rejected=0
oet5_comp=0
olsrd_pollsize=0.1
filter_tod3=
oet1_ipaddr=1.2.3.4
proftpd_sharedkey=
sb/1/tssipos2g=1
ezc_version=2
filter_tod4=
oet1_shaper=0
filter_tod5=
wl_stbc_rx=1
wk_mode=gateway
ddns_passwd_buf=
filter_tod6=
wl0.2_akm=disabled
rc_shutdown=
nstx_log=0
filter_tod7=
wl0_obss_coex=0
wl0_wds6_netmask=
NC_GatewayMode=Open
sdram_init=0x0000
filter_tod8=
wl_rts=2347
oet7_ipaddr=1.2.3.4
filter_tod9=
wl0_wds9_desc=
oet7_shaper=0
sb/1/antswctl2g=2
lan_wins=
wl_ap_isolate=0
lan_hwnames=
wl_mac_list=
dhcpd_options=
NC_IdleTimeout=0
dhcp_dnsmasq=1
wd_path=/wifidog
dhcpd_usejffs=0
wl1_country_code=US
pppoe_demand=0
wl_wme_no_ack=off
static_leases=
openvpncl_sec=1
wl0.3_auth=0
local_dns=0
wd_auth=0
filter_dport_grp10=
wl0_radius_key=
wl0_wds10_desc=
oet3_comp=0
ddns_username_buf=
wl0_wds10_netmask=
wl0_corerev=17
wl0_nmcsidx=-1
wd_enable=0
proftpd_rad=0
wl0_lazy_wds=
refresh_time=3
dlna_thumb=0
pci/1/1/regrev=0
wl0_channel=6
wl0_wds3_if=
usb_ses_umount=0
sb/1/ledbh0=11
pptp_encrypt=0
wl0_wds5_enable=0
oet6_en=0
usb_enable=0
sb/1/maxp2ga0=0x5e
sb/1/ledbh1=11
ddns_wan_ip=1
NC_ForcedRedirect=0
oet10_en=0
pci/2/1/regrev=0
sb/1/maxp2ga1=0x5E
sb/1/ledbh2=11
upnp_enable=0
dr_setting=0
wl0_wds10_enable=0
wl0_wds7_desc=
br0_mcast=0
sb/1/ledbh3=11
hs_redirect=
openvpn_ca=
nstx_ipenable=0
eth5_ipaddr=0.0.0.0
sb/1/cddpo=0x0
pptpd_lip=
wl0_wds4_hwaddr=
wol_hostname=
dhcpc_vendorclass=
openvpn_fragment=
proftpd_anon=0
sb/1/opo=0x0
filter_rule10=
wl0_stbc_rx=1
openvpn_dhcpbl=0
wl0.1_auth=0
wl_dfs_preism=60
rflow_if=br0
openvpncl_pkcs12=
nstx_ip=0.0.0.0
eth2_bridged=1
sb/1/rxchain=3
wan_dualaccess=0
ppp_mlppp=0
oet1_comp=0
NC_AllowedWebHosts=
wl0.3_closed=0
status_auth=1
dhcpc_requestip=
oet2_mssfix=0
autofw_port0=
boardnum=01
wl0_crypto=off
language=english
warn_enabled=0
wl0_txchain=3
sb/1/antswitch=0
hwmon_temp_max=60
olsrd_lqlevel=2
proftpd_writeen=off
wl_bcn=100
oet8_mssfix=0
ptoken=0
wl0_itxbf=0
wl0.2_bridged=1
wl_reg_mode=off
wl_wep_buf=
macupd_enable=0
hotss_operatorid=
wl0_wds3_ipaddr=
wl0_wds5_desc=
wl0_wds9_ospf=
openvpn_net=0.0.0.0
mmc_enable0=0
wd_username=
eth6_bridged=1
oet10_mssfix=0
upnp_config=1
limit_telnet=0
rflow_ip=0.0.0.0
oet4_bridged=1
filter_dport_grp1=
filter_dport_grp2=
rc_custom=
wl0_wds9_ipaddr=
oet1_fragment=0
afeng11
afeng11's picture
who can upload cfe for R6200
who can upload cfe for R6200 v1?I have bricked my router completely,i need reflash cfe via jtag,thanks
