Well, maybe not ALL aspects of your life, but it certainly turns networking your home theater from a big project to something much simpler. The kit contains one XAV101 Powerline Ethernet Adapter and an XAV1004 - a Powerline AV Adapter with an Ethernet switch.
Using this kit, you can utilize your Internet connection in your home office (or virtually anywhere in your home) and stream it wirelessly to where you have your entertainment center or home theater located; enabling you to connect up to four devices. You can connect almost anything, including (but not limited to) video game systems, NETGEAR ReadyNAS, NETGEAR Digital Entertainer Elite, Slingbox, TiVo, Vudu, and much more.
Features
- Turn a power outlet into a high speed Internet and home network connection
- Connects up to 4 devices
- Delivers fast 200 Mbps speed, fast enough to stream HD video
- For use with both wired and wireless routers and gateways
- Simply plug an XAV101 into your router and connect as many as 4 Ethernet-ready devices to the XAV1004
- Port-based Quality of Service (QoS), ensures that the highest priority applications are allocated more bandwidth
- Red, yellow, green status LEDs indicate maximum data rate
- 128-bit AES data encryption ensures privacy and security, secure your Powerline AV network by just pushing a button
- Supports Windows® Vista™
- HomePlug AV compatible
- Connect a variety of devices:
- Game consoles including Xbox 360™ and Playstation 3®
- Networked attached storage devices including: NETGEAR ReadyNAS, Notebook PCs, Wired and wireless routers, TiVo®, AppleTV®,VUDU® box, Desktop PCs, Slingbox™, BD Live™ enabled Blu-ray player
