Quick Review and Specifications: NETGEAR R6300 Wireless 802.11ac High Speed Router
The NETGEAR R6300 WiFi Router delivers next generation WiFi at Gigabit speeds. It offers the ultimate mobility for WiFi devices with speeds up to 3x faster than 802.11n.
Compatible with next generation WiFi devices and backward compatible with 802.11 a/b/g and n devices, it enables HD streaming throughout your home. The R6300 with simultaneous dual band WiFi technology offers speeds up to 450+1300 Mbps and avoids interference, ensuring top WiFi speeds and reliable connections. This makes it ideal for larger homes with multiple devices. In addition, four Gigabit Ethernet ports offer ultra-fast wired connections. Wirelessly access and share USB hard drive and USB printer using the two USB 2.0 ports.
The NETGEAR genie app provides easy installation from an iPad, tablet, computer or smartphone. It includes a personal dashboard, allowing you to manage, monitor, and repair your home network. NETGEAR customers can download the app at http://www.netgear.com/genieor from the Google Play or App Store.
Features of the R6300 802.11ac Wireless Router
  • WORLD'S FASTEST WIFI — Up to 450+1300‡ Mbps†
  • GIGABIT WIFI — Next generation WiFi now at Gigabit speeds
  • GIGABIT WIRED — Ideal for HD gaming & video
  • SIMULTANEOUS DUAL BAND — Reduces interference for better connections to more WiFi devices
  • DLNA® — Find & play your media on DLNA TVs & game consoles
  • ReadySHARE® USB ACCESS — Wirelessly access & share USB hard drives via two (2) USB ports
  • ReadySHARE® Printer — Wirelessly access & share a USB printer
  • ULTIMATE RANGE — WiFi coverage throughout your home
  • EASY INSTALL — Easy setup for iPad®, tablets, smartphones & computers
  • NETGEAR GENIE® APP — Personal dashboard to monitor, control & repair your home network
  • PUSH 'N' CONNECT — Easy push button WiFi connections (WPS)
  • WIFI & POWER ON/OFF — Convenient power savings
  • PARENTAL CONTROLS — Web filtering for all your connected devices
  • GUEST NETWORK ACCESS — Separate & secure access for guests
  • SECURE WIFI CONNECTIONS — Highest level wireless security with WPA/WPA2
Performance Features
  • WiFi Boost with high-powered radio amplifiers
  • Memory: 128 MB Flash and 128 MB RAM
  • Advanced Quality of Service (QoS)
  • IPv6 Support (Internet Protocol Version 6)
Tags:
