The NETGEAR N300 Wireless Router + Built-in Powerline AV allows you to share your broadband connection with multiple computers and other devices throughout your entire home. It provides the convenience of wireless with Powerline for easy, reliable and secure network access from any electrical outlet. This all-in-one solution means simple setup and reduced clutter, while NETGEAR Live Parental Controls keep your Internet experience safe by blocking inappropriate content.
- Connectivity — Share broadband connection with multiple computers and other devices, such as gaming consoles, Blu-ray™, DVD and HDTV
- Reliable — Powerline provides easy, reliable and secure network access from any electrical outlet
- All-in-one solution — Kit with wireless router and Powerline AV provides a complete solution with easy setup and reduced clutter
- Easy setup — NETGEAR Genie™ installation CD for step-by-step setup
- Safe Internet — NETGEAR Live Parental Controls keep your Internet experience safe by blocking inappropriate content
- NETGEAR Green features — Power and Wi-Fi on/off buttons, 80% recycled packaging
Package Contents
- N300 Wireless Router (WNR2000v3)
- Powerline AV Adapter (XAVP1000)
- Stand for Wireless Router
- Ethernet cable
- NETGEAR GenieTM installation CD
Warranty
- Localized to country of sale
WNXR2000 Specifications
Advanced Features
- Live Parental Controls with flexible and customizable filter settings
- Multiple SSID guest networks (separate security and access restrictions)
- Broadband usage meter measures Internet usage
- Power and Wi-Fi on/off buttons
- Supports Wireless Multimedia (WMM) based QoS
System Requirements
- Broadband (cable, DSL) Internet service and modem with Ethernet connection
- 802.11 b/g/n 2.4 GHz wireless adapter or Ethernet adapter and cable for each computer
- Microsoft® Windows® 7, Vista®, XP®, 2000, Mac OS®, UNIX® or Linux®
- Microsoft® Internet Explorer® 5.0, Firefox® 2.0 or Safari® 1.4 or higher
Standards
- IEEE® 802.11 b/g/n 2.4 GHz
- Five (5) 10/100 Ethernet ports with auto-sensing technology. (1 WAN, 3 LAN, and 1 LAN for Powerline AV connection)
- HomePlug® AV2 compliant
Physical Specifications
- Dimensions: 177.5 x 130 x 35 mm (7 x 5.1 x 1.4 in)
- Weight: 0.68 kg (0.88 lb) - Powerline AV Adapter (XAVP1000)
- Dimensions: 98 x 67 x 56 mm (3.85 x 2.63 x 2.2 in)
- Weight: 0.33 kg (0.71 lb)
Security
- Wi-Fi Protected Access® (WPA/WPA2-PSK) and WEP
- Double firewall protection (SPI and NAT firewall)
- Denial-of-service (DoS) attack prevention
- Exposed Host (DMZ) for secure gaming
Ease of Use
- Push 'N' Connect using Wi-Fi Protected Setup® (WPS)1
[Learn more at the official NETGEAR Website]
