A while ago I used this guide:
http://g300nh.blogspot.com/2010/06/software-installation-on-dd-wrt-part-1.html
and installed opkg, nano, and samba on my dir825 running 15437.
Today I ran the command opkg install libc to check for updates and it installed libc 0.9.3-60 on my router.
After that, everything breaks. nano returns xterm errors, swap dies, samba fails to start, and I cant install any packages because wget returns 255.
Is there any way to fix this???
Any help would be very very very appreciated!!!!!
Login and run command:
export LD_PRELOAD=
After that you should be able to use opkg again and commands to delete the never libc which you installed through opkg.
I actually solved the problem by setting and target in opkg.conf from snapshot/packages to backfire/packages where they still have the old libc. But I think someday they will update that too
In general this is no problem, since you can force the use of a specific library e.g. libc to be used when you start an application, that's what I do if I create ipkg packages with openwrts toolchain.
