I already have a R7000 running a FreshTomato firmware, but bought a R6700 for more ports and more wireless coverage.
I knew it is supported in the 2019.3 version:
https://exotic.se/freshtomato-arm/v2019/2019.3/K26ARM-NG/
But there seems no initial install for this router:
https://exotic.se/freshtomato-arm/Netgear%20R-series%20initial%20files/
Is there another source for an initial firmware? (B.t.w the R6400 initial firmware is refused)
Thank in advance!
Here is the initial file for the R6700V3:
https://bitbucket.org/snowman58/freshtomato-arm/downloads/freshtomato-R6...
This is for the R6700 V3.
The R6700 V1 and V2 are not supported.
anychance we can get R7800 support for FreshTomato?
Currently Freshtomato only supports Broadcom processors. The R7800 uses Qualcomm Atheros IPQ8065.
