Hello i used "erase linux" in dd-wrt and it bricked my router. Now i can not connect by LAN, so i connect to ttl and see:
CFE for WNR3500Lv2 version: v1.0.9
Build Date: Fri May 6 11:54:17 CST 2011
Init Arena
Init Devs.
NFLASH Boot partition size = 524288(0x80000)
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.60.136
CPU type 0x19749: 480MHz
Tot mem: 131072 KBytes
Device eth0: hwaddr C4-04-15-0A-BB-E8, ipaddr 192.168.1.1, mask 255.255.255.0
Checking crc...Invalid boot block on disk
Device eth0 has been deactivated.
Start TFTP server
Reading :: Failed.: Interrupted
Found a AMD NAND flash with 2048B pages or 128KB blocks; total size 128MB
Decompressing...done
These lines are constantly repeated. When i press ctrl-C i can type tftpd, but i can not use lan on a router, because the router doesn't want to connect to my computer. Just burning yellow led.
What should I do to reflash the router?
