When you upgrade to DD-WRT on your WNR3500L, you'll find that the new firmware requires a file that ends with the BIN extension, if you ever want to upgrade or change your firmware from that point.
So, if you decide, for example, to revert back to the original NETGEAR firmware - you can't because that firmware has a filename that ends in CHK.
As such, this makes it harder to change back. One way to do it is to use a serial console, but if you don't have one... here's a way to accomplish it in Windows without one.
Fortunately, included in the DD-WRT firmware is an erase utility that will wipe the firmware and allow you to upload a new one.
Here is how it's done.
You first have to Telnet into your router.
To do this simply open up a CMD window and type Telnet 192.168.1.1 (or the location of your router)
You will then need to type in the name and password for your router. If you have not changed it form the original setup, then they would be Name:admin and Password:password.
Once in, you will be shown a prompt that you can use to erase the old firmware.
Type in "erase linux" and it will run and show you its progress.
Once complete, it will again show you a command prompt.
Type in "reboot" and you should see "Connection to host lost"
You can then close this window.
Now we need to put the new firmware on.
Wait about 5 minutes for the router to reboot and then open up a new CMD window.
You will then use TFTP to put the new firmware on the router. This program comes with Windows XP. If you are using Vista, you need to install it.
1. Open the Control Panel and select the Programs entry.
2. From the Programs and Features section, select Turn Windows features on or off.
3. Scroll down the list and place a check in the box next to TFTP Client. Click OK.
4. Give Windows a moment or three to install the tftp client. When its done, exit out of the Control Panel.
Open up a CMD window and type in "tftp -i 192.168.1.1 PUT NameOfFirmware.CHK" as shown below.
Wait a few minutes and you should see "Transfer Successful"
At this point all you need to do is wait. The router will install the firmware and reboot automatically. This could take 5 to 10 minutes.
Once the router is finished booting you can go back into your browser and setup your desired configuration.
nice one.... very good step-by-step tutorial
can you not run "erase linux" from dd-wrt's command web ui?
Unfortunately did this tutorial brick my router... :-(
I ran "erase linux" and "reboot" and after the router rebooted I couldn't connect to it anymore (no DHCP lease) and the power led blinks (green).
I'll see what happens if I assign a static IP and gateway, but my hopes aren't up...
Anyone ideas accept waiting for the USB-TTL cable and follow the debrick procedure?
Update: Static IP & Gateway did the trick! A good idea would be to update the tutorial with that information. When the router reboots the attached PC will try to obtain a new IP using DHCP (which didn't work in my case) thus assigning the "couldn't get a IP"-address 169.x.x.x and therefore I was unable to tftp to 192.168.1.1.
Will adding DD-wrt or 3rd party fw to this router void my warranty????
I recently did all of this but at the last step its saying it timed out.
I have Windows 7 ultimate 64 running XP virtual mode
DINT WORK ROUTER POWER LIGHT FLASHES GREEN AND THE FIRMWARE DOES NOT FLASH CAN SOME ONE PLEASE ADVISE ME ON WHATTO DO NEXT
am sure i tried this i also tried to send wrt back but was a no go phoned them and got it rma'd cost me £3 to send it back recorded
I did erase linux and tried to tftp but it wouldn't take. Basically there's no OS on the router.
My WNR3500v2 successfully accepts tftp after tftp without doing anything, always returning to flashing green power LED.
I've tried two different revs of Netgear factory firmware, I've tried the two files listed in the DD-WRT router database for WNR3500v2, and I've tried teddy_bear's Tomato beta. The factory files successfully complete tftp but nothing happens. The other ones cause the router to go offline, and after waiting a long time, I reset it only to come back to a continuously blinking green power LED.
Ping continuously returns TTL=100 which I read to mean it's ready for tftp.
I've also tried shorting the two pins to reset the NVRAM as posted by fabien somewhere on this site.
Help?
It worked great for me, no flashing green light and the router works fine with one exception:
- I can't log in on the router. Have tried admin & password, root & admin and all other combinations of usernames and password that I used during my 1-day dd-wrt era. Turned the thing off and resetted to factory settings and tried the above usernames and passwords again. Still no access.
Any ideas anyone?
Update: A Hard Reset did the job. The reset I mentioned above was not according the the "simple reset" or "30-30-30 reset" described elsewhere in this forum.
So does this process require that the user assigns a static IP address to their own computer in order to perform the reflash? (if so, how does one do so?)
I'm trying to get back to factory firmware after trying a version of DD-WRT on this site that isn't nearly as stable as the factory original.
also, do you have to specify the directory where the factory firmware is located?
Alright! I completed the flash successfully!
I followed the steps above, and when it came time to tftp the router I changed directories in cmd to where I had the router firmware stored, then tftp'd it. I also made sure to assign a static IP to my computer before doing this. I think these are some crucial steps that should be added to this post to ensure clarity and allow everyone to successfully complete the flash.
http://www.youtube.com/watch?v=dfry1lmlWg4
Simply use tftp from a linux terminal, yes the above process is shown with a windows command prompt, but tftp is in linux as well.
Two notes for anyone having issues:
Before doing this procedure, make sure the IP of the router is 192.168.1.1! I had changed mine to something custom, but it would only allow me to tftp to 192.168.1.1, which meant I had to assign a static ip locally, yadda yadda.
Also strange, after restoring the factory firmware it went back to my custom IP, but I could not login. A hard reset (via the button) fixed that.
Follow the tutorial from the link below
works perfectly
Good job Matt
This procedure has worked for me 2 out of 2 times (and confirmed by another member) to flash Netgear stock firmware back from Tomato 9047:
This is what I did going from tomato 9047 to Netgear 1.0.2.50. After a 30-30-30, I simply upgraded to Netgear 1.0.2.50 in chk format. It took, but the power light keeps blinking.
At this point, I power cycled (30 sec), did 30-30-30, and then tftp'd to 192.168.1.1 [ tftp -i 192.168.1.1 put filenameofnetgearfirmware] (NOTE: I HAVE ALSO SUCCEEDED EVEN WHEN YOU SKIP THE POWER CYCLE AND 30-30-30. JUST TFTP DIRECTLY.)
Wait 5 minutes, power cycle, 30-30-30...VOILA.
IN MY EXPERIENCE, IT IS IMPORTANT THAT YOU SET A STATIC IP ON YOUR PC WHEN PLAYING AROUND WITH ROUTER FIRMWARE UPGRADES!!
@Heintz, got exactly the same problem. I didn't actually figure out that I need to set a static ip on my PC after erasing DD-WRT.
But I was able to re-flash it from that point back to the original firmware using "Firmware recovery utility" that is on the bundled CD.
I think this whole process of re-flashing could be done from very beginning using that Netgear's recovery utility rather than telnet-ing and tftp-ing... I presume it's just does all these steps from tutorial in the background. Am I right?
ok, works fine from tomatoUSB 9049 to Netgear 1.0.2.50, no problem.
aloa from paris
Followed the same steps on Mac OSX using telnet and tftp utilities in terminal. Worked perfectly.
If anyone is interested here are the screenshots: http://dmlogs.imgur.com/flash_to_factory_firmware_wnr3500l
I tried to do this in linux.
After the "reboot" command I tried to tftp but apparently the commands aren't the same and I couldn't get it to work.
I eventually gave up trying to upload the new firmware and pinged the router. Over many trials, 30-30-30 resets, and more, it didn't reply to the ping. What can I do!?!
I did this, minus all the shorting stuff. In addition, I also assigned a static IP to my NIC. Some of the other comments on this page explain how to do that.
If you keep getting a flashing green light and the tftp command is not working. I have the most easiest fix. Just pop the CD in your PC. Have that ethernet cable still hook up. set IP 192.168.1.8, 255.255.255.0, 192.168.1.1 is default gateway. Run the recovery utilty from the CD and it'll put eveything back like it was. You may still have to do up to the erase linux part of this tutorial but after that the CD will take it from there if you run into problems. Hope this helps. It help me.
hi, if you are on a MAC you can use MacTFTP to upload the original FW to the router. The tftp program on Mac OS X doesn't word with the "-i" option, so it is easier to use MacTFTP.
Get it here:
http://www.macupdate.com/info.php/id/12146/mactftp-client
Btw. I had to turn off/on the router to get the router to accept the incoming FW.
If you are on Mac OS X you can use a small TFTP client to upload the FW to the router. The original tftp program on the Mac doesn't accept the "-i" option and didn't seem to work for me.
PS I had to restart the router after the "reboot" to get it to accept the upload.
Thanks for the help with this one. It got my router up and running with no trouble by following the video tutorial.
Heey Guys,
I'm all new to this and I'm Trying and learning atm,
I tried to flash my Ntegear WNR3500L to that DD WRT and I guess something went wrong, I've got a orange power LED NOT blinking just Orange all the time,
when I try the Telnet 192.168.1.1, my CMD says "Busy Connecting..." then comes with "Can't connect to host, on port 23: Connection failed"
So I figured since nothing works, maybe there's just no firmware on it, so I tried the TFTP thing, and it takes very long and then my CMD says "Time-Out Occured"
So please can someone help me what can I do, without using the TTL cable preferly,
I'm sorry if the CMD lines aren't right I have a Dutch machine here so I tried translating it =P
Please help me cause I don't know What to do...
Thanks in Advance
Greets:
Thursten
Have you done 30-30-30 resets ?
Try again 30-30-30 !!
Thanks man, But Ain't Working =(
I tried 3 times but it don't seem to work still an orange Power LED ... =(
Anyone else an idea ??
Pleaaassee ??
Greets:
Thursten
