When using wireless networks, range and data throughput rates are highly variable. Poor range and throughput may be caused by a range of factors, but can usually be improved by the following :
- Choosing the Best Locations
- Tuning Your Equipment
- Choosing the Right Equipment to Upgrade
- Testing your improvements. Testing Wireless Range explains the options.
Better equipment can provide a quick fix. But the best approach is to work on all four items.
Wireless routers, access points, and adapters send and receive radio wave signals through antennas. The antenna is hidden inside adapters, but on routers and access points there's can be either a visible antenna or internal. Radio waves can be focussed like a lightbulb. And like a light, some materials reduce or stop radio waves. While light focused from several lights is brighter and makes it easier to see, several antennas in the same area cause interference — the radio signals will be muddy and confused.
Your goals in optimizing power are:
- Avoid obstacles.
- Avoid interference.
- Increase signal strength. Power affects how far an antenna radiates.
- Use the equipment in places it's most powerful and most sensitive.
Antennas don't radiate equally in every direction. Just as the base of a lightbulb blocks light, and just as a light can be focussed by a reflector, so an antenna signal may be blocked and focused. Since people cannot see radio waves, you'll rely on testing and trial-and-error to get an idea of where antennas "shine" most brightly. An adapter's antenna is important, but the most powerful and sensitive antennas are on routers, access points, and detachable external antennas.
One final concept before you go to the above links is interference. Interference is a signal — one you don't want — at the same frequency as the one you're using. Interference comes from devices such as microwave ovens, cell phones, 2.4 GHz cordless phones, and copy machines. Interference is also caused when your own wireless signals are bounced off reflecting objects. Objects may partly or completely absorb signals, reflect them, bend them, or let them pass right through. Metal and water (including the water in people!) absorb or reflect signals. Air, wood, and glass tend to let signals pass with weakening. And when outdoors, plants and the weather may cause interference.
Improving Wireless Range: Choosing the Best Locations
This describes moving equipment, positioning antennas, and avoiding obstacles. When optimizing your existing equipment, consider: NETGEAR Powerline Adapters
- Placing routers or antennas in a good location, at a good angle.
- Avoiding physical things that block signals.
- Reducing the interference from other things that transmit radio waves.
Before starting adjustment, make sure that antennas and cables are securely fastened!
If your network has more than a couple wireless devices, before you move things, decide which wireless devices are transmitting the heaviest load. These links are important to optimize. NETGEAR products have automatic data rate fallback, which allows increased distances without losing connectivity. It also means that devices that are further away are inherently slower. Therefore the most critical links in your network are those where the traffic is high, and the distances are great. Optimize those, first. The ones that are least important are links that have little, occasional traffic, and which have a strong signal strength.
Picking Good Locations for Antennas
- Place high, and clear of obstructions as practical.
- Keep antennas 2 feet from metal fixtures such as sprinklers, pipes, metal ceiling, reinforced concrete, metal partitions. (However, antennas on roofs do not necessarily give the best results. )
- Keep away from large amounts of water such as fish tanks and water coolers.
- Antennas transmit weakly at the base, where they connect. So don't expect good reception from the bottom of a router or access point.
Router Orientation If your router comes with a stand it should be used to postion the router upright or correctly. If the router is layed flat you can lose quite a bit of range.
For multi-story buildings, placing antennas at 45 degrees (diagonally) or 0 degrees (straight out parallel to the floor) may be most effective.
Reducing Interference
Avoid windows unless communicating between buildings. (Windows let in interference from the outside world.)
Place antennas away from various electromagnetic noise sources, especially those in the 2400 – 2500 MHz frequency band. Common noise-creating sources are:
Improving Wireless Range: Tuning Equipment
Using the best channels has a big effect on network performance. Your goal is to choose settings that avoid interference from other networking and radio frequency equipment. (If you have 802.11a or 802.11a/g, channel selection is less important.
If you have a simple home network, and aren't close to neighbors with wireless equipment, you may be lucky enough just to choose between many channels that work well.
Complications arise when:
- You want much better coverage than you're getting.
- You use multiple access points or wireless routers. (Then you'll probably be using more than one channel.)
- You aren't the only person nearby running a wireless network.
Simple Spacing of Channels
As explained in Improving Wireless Range: Overview, improving signal strength is not like adding more lights to get a brighter livingroom. Devices that transmit powerfully — such as routers, access points, and cell phone base stations — confuse one another. It's necessary to distance them and to have them use different channels.
For 802.11b and 802.11g, there are 11 channels for wireless equipment (13 channels in Europe). In the simple situation where there's little interference, you can choose any channel that works for you. When there is interference from wireless networks that overlap with one another, each network should use one of the non-overlapping channels: 1, 6, or 11 (1, 7, 13 in Europe). Then, 3 networks can use the same space with minimum interference. If you can't do that, choose channels as widely spaces as possible.
| You can use a combination of access points and antennas and other equipment to create local "spotlights" of strong transmission, rather than trying to cover everywhere. |
What If a Channel I Want to Use Has Too Much Noise (Interference)
If your neighbor has a wireless network, it wouldn't be surprising that they are already using channel 1 and channel 11. Unfortunately, you can't completely avoid interference just by using other channels. Wireless protocols 802.11b and 11g only have 3 non-overlapping channels. Therefore when 4 or more channels are used in the same area, the level of interference can increase notably. If you and your close neighbor both have a router and a wireless access point, for example — which makes a total of four powerful transmitters — both of you will have a certain amount of interference.
If there's a severe problem, a practical and sociable thing is to talk to your neighbors using wireless networks that can be seen when you scan. Together, you can choose optimal channels for your respective networks. You'll want your own channels at least 5 apart. So, for example, you could use channels 1 and 8, and your neighbor could use 5 and 11.
You may be able to place routers and access points further away inside your homes. After all, the kinds of physical barriers that reduce your transmission range also reduce the signal that your neighbor doesn't want to see.
If you can use a directional antenna, or an antenna cable to shift an antenna, that can help you both. See the articles on antenna selection.
Reducing Wireless Network Traffic
When there's noise, your network performance drops, so one approach is not to stop the noise, but to reduce the amount of network data being transmitted.
In a noisy environment, it may be useful to keep part of your network wired. If Ethernet cabling isn't an option, consider Name Your Link — using existing home wiring instead of cables.
When SSID Broadcast is turned on, it's easiest for equipment to find the strongest signal. However this also causes network overhead. When the SSID is broadcast, your neighbor's equipment may keep a record of it, and automatically try to connect several times a second; this can cause significant performance reduction. So where there are close networks, turn off SSID Broadcast, and change the default SSID.
Turning off WEP and WPA may increase network throughput, but exposes your network to hackers. This is not recommended, except for testing purposes.
Improving Wireless Range: Choosing the Right Equipment
This article is useful:
- To compare how various wireless devices should be used, or
- If Choosing the Best Locations and Tuning Your Equipment don't get the performance you want, or
- You want a big improvement immediately at a reasonable cost.
The cheaper solutions are first, followed by more expensive, but very powerful ones. A network with more than a few computers may benefit from a combination of approaches.
I. A New Router II. A Second Router as a Wireless Access Point III. Powerline IV. An Access Point V. An Antenna
I. A New Router
Replace your existing router with a better one. This is recommended if your router is a couple years old. A new router will probably double your coverage in a single area.
Advantages
- Making the change is likely to be simple. New NETGEAR routers come with wizards that make basic installation easy, and will probably fit with your existing network with few other changes.
- The newest NETGEAR routers are excellent values.
- New routers can deal with tricky wireless environments without any tuning at all.
Disadvantages
- May require you to also buy new adapters to get all the router benefits.
- Isn't best for difficult environments with spotty coverage, or for covering large areas such as entire buildings.
II. A Second Router to use as a Wireless Access Point
With this solution you disable features of a wireless router, leaving the wireless transmitter working. This configuration uses an existing wired or wireless router.
Advantages
- Low cost. With an inexpensive router, this is the cheapest solution.
Disadvantages
- NETGEAR provides no free support at all for this.
- NETGEAR routers are not designed for this purpose, so configuration, behavior, features, and performance may not be as expected. Problems may include no DHCP passthrough and stopping access point roaming.
- Only suitable for small, moderately loaded networks. E.g., not good for running a game server or a database server.
- Can be slightly difficult to configure.
III. Powerline
Instead of networking through the air, or through Ethernet cables, Powerline uses the existing electrical wires in your walls.
Advantages
- Fairly low cost.
- Excellent solution in difficult RFI environments, since Powerline signals don't go through the air.
- Good security for casual users.
- Powerline can easily be moved in a house. No reconfiguration is needed, units can be plugged in where and when you want.
- Doesn't require continuous wireless coverage, just an available electrical plug.
- Works nicely with wireless technology to cover "blind spots".
Disadvantages
- Powerline performance is not limited by RFI, but it is limited by noisy power. As with wireless, it's difficult to know exactly how well Powerline will work until you try it.
- Powerline is often not suitable for businesses, dorms, and hotels. See Assessing Powerline for Business Environments.
IV. An Access Point
Dedicated access points have better performance and features than routers that are used as access points (see above).
Advantages
- Can cover an area far distant from your wireless router, without having to cover all the area in between.
- Potentially excellent LAN performance, especially with careful configuration and placement.
- Advanced security features.
- Access points are covered by NETGEAR's free support policy.
Disadvantages
- Business access
- Using access points in repeater mode does not result in the best performance.
- Configuration is more complicated than other solutions.
V. Antennas
Antennas can provide great power. NETGEAR antennas and boosters are available in the United States that transmit for miles. Less powerful antennas may still cover an entire building.
Advantages
- Antennas give excellent throughput over large continuous areas.
- Antennas are available for outdoor, as well as indoor use.
- Antennas are often the most practical solution for networking between buildings.
Disadvantages
- Antennas must be connected to equipment specifically designed for them. This adds to cost.
- A site survey may be needed before installation. (See below.)
- Antennas may require professional installation. This adds to cost.
- In thunderstorms, connections may be slow or temporarily interrupted. Critical networking or networking in areas of frequent storms may require other network connections as a backup.
- Regulations in all countries limit how antennas can be used.
Category:
