The NETGEAR A6200 WiFi Adapter delivers next generation WiFi speeds. Compatible with next generation WiFi devices and backward compatible with 802.11 a/b/g/n devices, it enables multiple HD video streams throughout your home simultaneously.
With up to 300/867 Mbps† speed and dual band technology, the A6200 avoids interference, ensuring top WiFi speeds and reliable connections. The optional antenna positioning offers optimal performance and reliability, while the unique design features of the adapter make it easy to use with both laptops and desktops. The A6200 WiFi Adapter is perfect for upgrading your existing laptop or desktop to 802.11ac.
Features of the A6200 802.11ac Wireless Adapter
- NEXT GENERATION WIFI—300/867 Mbps† speeds
- ANTENNA — Optional antenna positioning for additional performance
- DUAL BAND — Reduces interference for better connections to more WiFi devices
- COMPATIBLE — Works with 802.11 a/b/g/n and ac devices
- NETGEAR GENIE® — Dashboard controls to connect a WiFi device to your home network
- PUSH ‘N’ CONNECT — Secure push button WiFi connections (WPS)
- EASY INSTALL — Includes NETGEAR genie software on a CD for simple installation
- ULTIMATE RANGE — WiFi coverage throughout your home
The A6200 is great for:
- Emailing, chatting, surfing, music and video streaming
- Online gaming
- HD Streaming
- Multiple HD streaming simultaneously
Specifications of the A6200 USB Wireless Network Adapter
Package Contents
- A6200 WiFi USB Adapter—11ac Dual Band (A6200)
- USB cable with desktop dock
- Installation guide
- NETGEAR genie® installation CD
Warranty
- Localized to country of sale. For warranty and support details in your region visit support.netgear.com.
System Requirements
- Intel® Pentium® class PC
- Available USB 1.1 or USB 2.0 slot
- Microsoft® Windows® 7, XP, Vista®: (32/64-bit)
Standards
- IEEE® 802.11 b/g/n 2.4 GHz
- IEEE 802.11 a/n/ac 5.0 GHz
Physical Specifications
- Dimensions: 95.3 x 31.4 x 14.3 mm (3.75 x 1.23 x .56 in)
- Weight: 19.5 g (0.69 oz)
