Netgear N600 Wi-Fi Cable Modem Router (C3700)
Faster Cable Internet. Dual-band WiFi. One device.
N600 Dual-Band WiFi router with integrated DOCSIS 3.0 cable modem
- Own your Cable Modem—stop paying modem rental fees!
- Next generation DOCSIS 3.0 technology—8x faster cable Internet download speeds, up to 340 Mbps
- Fast Dual Band WiFi Speeds—N600 WiFi
- NETGEAR genie—easily install, monitor & control your home network
- Gigabit Ethernet Ports for fast wired connections
- USB port to wirelessly share your hard drive
- Compatible with major U.S. Cable Internet Providers like Cablevision, Charter, Cox, Time Warner Cable, XFINITY, and more
Easy Installation
- Easy Install—Easy setup for iPad, tablets, smartphones and computers
- NETGEAR Genie APP—Personal dashboard to monitor, control & repair your home network
- Push ‘N’ Connect—Easy push button WiFi connections (WPS)
- WiFi & Power ON/OFF—Convenient power savings
Security
- Live Parental Controls
- Parental Controls—Safer web surfing for all your connected devices
- Guest Network Access—Separate and secure access for guests
- Secure WiFi Connections—Highest level wireless security with WPA/WPA2
Sharing
- DLNA—Find & play your media on DLNA TVs & game consoles
- ReadySHARE USB
NETGEAR genie App
- Home network manager
- Makes any printer AirPrint compatible to print from an iPad or iPhone
- My Media—Find and play media files in your network
- EZ Mobile connect—Scan QR code to connect to your home network
- Turbo-Transfer—Quickly transfer files within your home network across various devices 40% faster than normal file transfers
- For PC, Mac, iPhone, iPad, & Android device
