Based on what we've seen and read, the Centria all-in-one home networking solution from NETGEAR looks quite impressive. We want one! (Keep your eyes open for a community review if we get a chance to test one out.)
Basically, the Centria is a wireless router, backup service, and network media storage device combined into one package. Two flavors are available: the WNDR4700, which comes with no internal storage but is easily upgradeable, and the WNDR4720, which comes with a 2TB hard drive pre-installed.
The Centria has three main functions:
- Automatic Backups: Set your PC's and Macs across the network to back up to the Centria automatically.
- Media Sharing: Use the Centria to stream movies, music and photos as well as provide remotely accessible data storage.
- Wireless Router: The Centria also functions as a wi-fi router, providing high speed, dual band connections and enhanced coverage for larger homes.
Both models of the Centria are available now from Amazon.com!
NETGEAR Centria WNDR4720 and WNDR4700 Specifications
- Faster WiFi - Now up to 900 Mbps
- Improved 5 GHz range
- Automatic, continuous back-up for your PC & Mac—ReadySHARE® Vault and Apple® Time Machine-compatible
- Removable, easily upgradeable internal hard drive
- Two SuperSpeed USB 3.0 ports for greater storage capacity or other USB device connectivity—up to 10X faster than USB 2.0
- ReadySHARE Cloud—for secure, remote access to personal content
- Single-click SD card back-up
- Easy to install—no CD required
- NETGEAR Genie Dashboard and Mobile App
- Dimensions: 256 x 206 x 85 mm
- Weight: 0.87 kg (1.91 lb)
- Five (5) 10/100/1000 (1 WAN and 4 LAN) Gigabit Ethernet ports with auto-sensing technology
- Two (2) USB 3.0 ports
- One (1) SD card slots
- IEEE® 802.11 b/g/n 2.4 GHz
- IEEE 802.11 a/n 5.0 GHz
- Use laptop with 3x3 450 Mbps adapter like Centrino® 6300/5300 for maximum performance
- WiFi Protected Access® (WPA/WPA2—PSK)
- Double firewall protection (SPI and NAT firewall)
- Denial-of-service (DoS) attack prevention
