Quick Review & Specifications of NETGEAR's WN1000RP WiFi Booster for Mobile
NETGEAR WiFi Booster for Mobile amplifies WiFi coverage for mobile devices in the home by extending and strengthening an existing WiFi signal, giving you the ability to enjoy an improved wireless experience on iPads and Android tablets, smartphones, netbooks and e-readers.
Features of the WN1000RP WiFi Booster
  • Boost WiFi — Amplify your network by boosting the WiFi signal around the house and even outside on the patio
  • Ideal for Mobile — Extend your WiFi network for mobile devices like iPads®, iPods®, Android® tablets, e-readers, smartphones, and netbooks
  • Reduce mobile data charges — Reduce 3G/4G mobile data usage by connecting to WiFi while at home
  • Enhance Existing Equipment — Keep your current equipment and improve coverage to eliminate WiFi "dead zones"
  • Easy Install – Simple install for all devices using a browser, no CD needed
  • Push 'N' Connect — Push ‘N’ Connect using Wi-Fi Protected Setup® (WPS) allows for a quick and secure connection
  • Optimal Coverage — Real-time LEDs locate the best placement spot to provide optimal WiFi coverage
  • Universal Compatibility — Extends b/g/n WiFi signals from any existing WiFi router or service provider gateway like Belkin®, Linksys®, D-Link®, AT&T™, 2Wire®, Verizon, EarthLink®, NETGEAR® and others‡
  • Superior Security — Works with all security standards including WPA-PSK, WPA2-PSK, mixed mode and WEP
  • NETGEAR Green features — Power on/off button, 80% recycled packaging
Specifications of the WN1000RP WiFi Booster
Package Contents
  • WiFi Booster for Mobile (WN1000RP)
  • Installation guide
Warranty
  • Warranty localized to country of sale
Advanced Features
  • Extend Internet access for wireless devices like iPads®, iPods®, laptops, smartphones, e-readers, and more
  • Repeats 2.4 GHz Wi-Fi signals from devices made by NETGEAR® and other brands
  • Dynamic LEDs display real-time network connection status
System Requirements
  • 802.11 b/g/n 2.4 GHz wireless router or gateway
  • Microsoft® Internet Explorer® 5.0, Firefox® 2.0, Google Chrome®, or Safari® 1.4 or higher
Standards
  • IEEE® 802.11 b/g/n 2.4 GHz
Security
  • Wi-Fi Protected Access® (WPA /WPA2-PSK) and WEP
Ease of Use
  • CD-less installation
  • Push 'N' Connect using Wi-Fi Protected Setup® (WPS)1
Physical Specifications
  • Dimensions: 67 x 55 x 34 mm (2.64 x 2.17 x 1.34 in)
  • Weight: 0.1 kg (0.22 lb)
[More Information on NETGEAR's Official Site]
[Purchase a WN1000RP]
