Quick Review & Specifications of the Trek Travel Router and Range Extender
Instantly share any public Internet connection and stay secure with firewall protection for public hotspots with NETGEAR Trek™ Travel Router and Range Extender. With a powerful flip-out antenna, you’ll enjoy increased range whether you use it on the go, or at home. This compact device can be used as a router, range extender, access point or bridge to keep you connected wherever you trek.
  • Extend your existing Wi-Fi coverage throughout your home
  • Eliminate Wi-Fi dead zones in hard to reach areas
  • Create a private Wi-Fi network with firewall protection on public hotspots
  • No longer pay multiple access fees for each device
  • High-performance flip-out antenna
  • Boost the Signal of Weak Public Wi-Fi Hotspots
  • Convenient USB power options for use with laptops or wall-plug design
  • NETGEAR genie App-Dashboard to monitor, control & repair your network
    NETGEAR genie App
    • Easily manage, monitor & repair your network
    • Makes any printer AirPrint compatible to print from an iPad or iPhone
    • MyMedia—Find & play media files in your network
    • For PC, Mac, iPhone, iPad, & Android devices
WiFi Band
  • 2.4 GHz
Number of Ethernet Ports
  • Two (2) 10/100 Mbps (1 Internet/LAN and 1 LAN) Ethernet ports with auto-sensing technology
Key Features
  • Multipurpose WiFi device: WiFi router, WiFi access point, Hotspot and Range extender
  • N300 WiFi (802.11 b/g/n)
  • Palm-size for easy portability
  • Flip-out antenna for optimal WiFi coverage
  • Charge mobile phone via USB when wall-plugged
  • Micro USB powered for better mobility
  • Intelligence to detect between network modes
  • READYSHARE® USB—Wirelessly share and access USB storage
Security
  • WiFi Protected Access® (WPA/WPA2—PSK) and WEP
  • Software WPS PIN and PBC (Push Button Configuration) modes
  • Double firewall protection (SPI and NAT firewall)
  • Denial-of-service (DoS) attack prevention
  • DMZ for secure gaming
Physical Specifications
  • Dimensions: 3.39 x 3.31 x 1.30 in (86.5 mm x 86.2 mm x 32 mm)
  • Net Weight: 0.355 lb (161 g)
padag
Can you use this to share a
Can you use this to share a WIFI link between 2 tablet/ipads?
Eg In hotels/ motels the user can often only link one device to the WIFI service at a time.
Can this device enable
