Here's some detailed information about the newest open source router, the WGR614L, coming soon from Netgear. This platform is well suited to community developed firmware packages such as DD-WRT, Tomato, and others.
WGR614L Hardware Specifications
Physical Specifications
- Dimensions: 6.9 x 1.1 x 4.7 in (175.3 x 27.94 x 119.4 mm)
- Weight: 0.26 kg (0.57 lb)
Wireless Speeds
- Network Speeds: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, & 54 Mbps (auto rate capable)
- Modulation Type: OFDM with BPSK, QPSK, 16QAM, 64QAM, DBPSK, DQPSK, CCK
Routing Protocols
- Static & Dynamic Routing with TCP/IP, VPN pass-through (IPSec, L2TP), NAT, PPTP, PPPoE, DHCP (client & server), Bigpond
Application Support
- Works with most Internet gaming and instant messaging applications.
Functions
- Automatically detects ISP type, Exposed Host (DMZ), MAC address authentication, URL content filtering, logs and e-mail alerts of Internet activity.
Interface
- Internet/WAN: 10/100 Mbps (auto-sensing) Ethernet, RJ-45
- LAN: 4 ports 10/100 Mbps (auto-sensing) Ethernet, RJ-45
- Wireless: AP
- Frequency
- 2.412 ~ 2.462 GHz (US)
- 2.412 ~ 2.484 GHz (Japan)
- 2.412 ~ 2.472 GHz (Europe ETSI)
- 2.457 ~ 2.462 GHz (Spain)
- 2.457 ~ 2.472 GHz (France)
Firewall
- Stateful Packet Inspection (SPI), DoS Attack Protection.
Encryption
- 40-bit (also called 64-bit), 128-bit, and 152-bit (802.11g only) WEP Encryption, WPA (Wi-Fi Protected Access), WPA2-PSK, WPS
Antenna
- 2 dBi
Power Adapter
- 12.0 VDC, 1.0 A; plug is localized to country of sale
Warranty:
- NETGEAR 1-year warranty
Package Contents
- Wireless-G Router (WGR614)
- Setup CD
- Power Adapter
- Ethernet Cable
- Vertical Stand
- Warranty/Support Information Card
no mention of cpu chipset or wireless chipset. routing protocols & application support, functions, and firewall are not hardware, they're a software feature. we need specs on the cpu and wifi.
there is a comparative study of wgr614L and kwgr614. Please refer to the following link -
http://www.myopenrouter.com/blog/entry/10062/WGR614L---Router-for-develo... you can find hardware informationm there
try to make things clear to people.
