Instaling Firmware on Netgear VEVG2500
2 posts / 0 new
joand
joand's picture
I'd like to install an other firmware on Netgear VEVG2500. This is a quite rare product but an official firmware is available. The file is called VEVG2500_v07.00.02_with_Toolchain_src.zip and can be found on internet.
The matter is the firmware I have doesnt have an "update firmware menu".
The readme of the file mentionned above says:
This package is only supported on Fedora Core and Red Hat variants.
How to install and build the open source package
You should have the following files:
• VEVG2500-1DYGES_toolchain.tar.bz2
• VEVG2500-1DYGES.tar.bz2
As root cd to /opt and install VEVG2500-1DYGES_Toolchain.tar.bz2 as follows:
• tar –xvjf VEVG2500-1DYGES_toolchain.tar.bz2
From your working directory install the source as follows:
• tar –xvjf VEVG2500-1DYGES.tar.bz2
To make the source package execute the following commands:
• cd SW
• make PROFILE=VEVG2500-1DYGES VENDOR=IFX
The resulting upgrade file “App.upg” can be found at SW/targets.IFX/VEVG2500-1DYGES
This upgrade file can be applied from the modem’s GUI upgrade page if option is available.
I'm just a newbie and I don't know how do I execute these instructions.
Is it a command line? I tried to "telnet" the router but i'm not sure if it supports it, I had "connection refused" using puTTY. And I could't have a working command prompt with TelnetEnable on windows.
Can anyone tel me how do I have to do? thank you very much.
And, of course, if someone tell me there's a better firmware for this router, open source, I'll install it. I just want to get rid of the firmware I have on it, because it does not allow me to connect to my internet provider.
thanks
joand
joand's picture
more recent open source
more recent open source firmwares are available here: http://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL (VEVG2500-1NCGES).
But I still dont know how to install them...
