Can someone explain as to how the % in bandwidth add up to greater than 100% in tomato Qos basic setting page? Also, can the Qos be controlled via CLI using say busybox?
Hi Roy,
I have not seen any % for bandwidth in tomato QoS basic setting that extends beyond 100% .... In which case / parameter u r observing this value ...
QoS can be configured via CLI using nvram commands ... the parameters that can be set are qos_ack, qos_burste , qos_orates etc . ... just run a nvram show comaand on the board's console and search for the string "qos_" in the command out
put and u can see all qos parameters that can be configured through CLI/nvram ...
Hi Roy,
