xr500, hardware is almost same with r7800, with dumaos is released,
196 posts / 0 new
Hingbong
XR500 is on dumaos,and it's hardware is almost same.
Is there any way to flash the firmware of XR500 to R7800?
e38BimmerFN
NO support for DumaOS on
NO support for DumaOS on R7800. There are some differences.
XVortex
Why not ;-)
Why not ;-)
e38BimmerFN
I presume that NETDUMA and NG
I presume that NETDUMA and NG have specifically set this up on the newer HW for this model router for a specific reason and support reasons as well. This router has a specifc target and also NG probably doesn't want to support the older HW of the R7800. There are similarities however when it comes down to it, it's all how the code and the newer HW are implemented. NG and NetDuma probably want to focus and keep development on track with what they decided to come up with. IT's all up to them. Maybe one day they might open up, however it's there call. For now. It's the XR500 only.
juhimifife
DumaOS for R7800: https://www
Voxel
Pirate version. Hacked latest
Pirate version. Hacked latest binary firmware for XR500. Is not built from source codes.
Well, it was expected...
Hingbong
flash via TFTP, it doesn't
flash via TFTP, it doesn't boot.
XVortex
Huh, because it's silly just
Huh, because it's silly just edit the header...
Here is *PROPER* version by me.
Enjoy.
e38BimmerFN
So this will work on R7800?
So this will work on R7800? Load via TFTP or UI?
XVortex
UI. You just need to re
UI. You just need to re-configure it from scratch because settings will reset.
e38BimmerFN
Ok, i'll give this a go.
Ok, i'll give this a go. Should I want to go back to stock or Voxels FW, I presume I can do the same in reverse and just load the FW file in the UI and do a factory reset?
e38BimmerFN
Also can we update using new
Also can we update using new updates for the XR500 or will they need to be tuned for the R7800 each time theres an update for the XR500?
XSXS
Let us know how it goes,
Let us know how it goes, bimmer. Thx
e38BimmerFN
Installed it this morning.
Installed it this morning. Put it online this evening. Looking good so far. Running well. I have the radios disabled for now as I have to use a different wireless system. DHCP and reservations seems a bit quirky when I connected the rest of my network after a reboot. Not sure if this is odd behavior in the services or what. Just seeing odd behaviros when setting up a reservation. Also notice that the list of detected items doesn't seem to list all my connected devices, however this could be that I have some connected thru a wireless AP via LAN to LAN. I'll have to find some time to take the other wireless system offline an connect everything to the XR7800 and test more. Other than this, UI is good. Able to do everything that the XR500 does. Going to enjoy this I hope. I wish I could have been able to keep the XR500 I had however money is tight. This will be a nice work around to play with.
NAT Filter as Secure and Open and for NG routers OPEN is preferred for two or more game console behing the same router.
NAT test is reporing full cone nat with OPEN setting:
http://nattest.net.in.tum.de/individualResult.php?hash=b0438561fd8db98b775e25b18c54842b
Hope we can easily go back to stock FW as well with out any problems if needed. I presume we can. Hope XVortex can let us know about future updates. Would be a great 2nd recommendation behind Voxels FW for the R7800.
XSXS
Thanks for the update. I'm
Thanks for the update. I'm surprised you rank it #2, behind Voxel FW. I would think it should be better since it took netduma 2 years to develop it. Does the geo filter work? What about QoS? Isn't that broke on NG FW and Voxels?
e38BimmerFN
I like how Voxel handles the
I like how Voxel handles the back end packaged on his FW. Seems to keep things up to date and more to spec with packages. NG kind fails here. There are some broke items on the R7800 FW, however this is NG core code that Voxel doesn't or can't change. These fixes have to come from NG. Setting a static IP address for AP mode is broke also. Waiting for NG to fix this and other issues. I haven't been able to test Voxels recent v50 build yet. Seen some other posting about it in the SNB thread there. Last best working version is v37 or v38 I believe IMO.
ALL is working on the XR7800 at first glance. I'll try and get time during the week to play fully with each feature and see how it goes. I presume for now, there isn't any issues or should be any issues seen. If there is, I presume should mirror actual XR500 problems if there is any. I haven't been keeping track as other beta testing has my attentions with another model router.
XSXS
Thanks bimmer, I may give it
Thanks bimmer, I may give it a try tomorrow! Also thank you Voxel for all your hard work!
Voxel
You are welcome.
I can only repeat: Pirate version. Hacked latest binary firmware for XR500. Is not built from source codes. So there should be the same issues as in stock working on original XR500. Plus this version uses binary samba extracted from my 1.0.2.50SF. So samba should be fast ;-)
e38BimmerFN
Well considering the HW is
Well considering the HW is pretty much the same. Don't see any issues. If the Id is the only thing changed and maybe a package updated, seems to be working fine with the modified FW file. I presume at some point maybe a full build would be desired.
XVortex
It looks like the router has
It looks like the DumaOS has the Smart Connect (band steering) feature enabled that R7800 stock OS does not have.
River
Netgear beta tested the XR500
Netgear beta tested the XR500 firmware on the R7800, so no surprise it works with a few tweaks.
e38BimmerFN
Ya I see it and it's enabled.
Ya I see it and it's enabled...is working so far.
Thank you xVortex.
XSXS
I turned it off for now but
I turned it off for now but pretty cool feature.
Buffer bloat is really good with this firmware, way better than stock!
Voxel, how current is this version of the Duma OS?
XSXS
Or xvortex and thanks for
Or xvortex and thanks for posting this!
XSXS
e38BimmerFN
The version is the most
The version is the most current one from NG support site. Same version.
e38BimmerFN
xVortex will have to tune
xVortex will have to tune each FW version as they come out...
pege63
Seems not to work when its in
Seems not to work when its in AP mode cant login then works only in Router mode.
pege63
How do i restore FW now it
How do i restore FW now it would not take Voxel or NG FW?
kamoj
Install Windows 10 TFTP:
Then you have to do this with the router:
- power off
- press and hold a pin in the reset hole
- power on
- wait for power LED to stop flashing amber and start flashing white
- Release reset button
- Wait a little, the router is now in tftp-mode!
C:\>tftp -i C:\192.168.1.1 PUT R7800-V1.0.2.50SF.img
Transfer successful: 24305793 bytes in 9 second(s), 2700643 bytes/s
XVortex
Sorry, there are some checks
Sorry, there are some checks in dumaos fw that prevents to back to 1.x.x.x fw.
Here is the solution. Just unzip it and flash it from the GUI and it brigs You to the R7800-V1.0.2.46 stock fw.
