So I can gain access by serial cable and tftp a firmware file to the router but my board id has become corrupted and looks like ≡i. I have backups of my boot and board_data partitions if that will help, I just can't figure out how to flash the board_data from cfe. If I knew the offset for the partition i could flash it easy enough. I have been unable to find the mtd structure anywhere but I know board_data was mtd4. The only other option I can see is if someone had a dump of the full flash I could use to get the router revived, I know how to flash my board_data from telnet using dd but that isn't an option in the cfe
- After the initial Kong Mod 4 months 3 weeks ago
- Working the EXACT same 4 months 3 weeks ago
- While the "5 Easy Steps" 5 months 5 days ago
- R8000P would be grate to see. 5 months 6 days ago
- Have a R8000 but ordered a 5 months 6 days ago
Maybe there is something in here that would help you.
https://openwrt.org/docs/techref/bootloader/cfe
