The NETGEAR EX3700 WiFi Range Extender boosts your existing network's range to deliver AC dual band WiFi speeds of up to 750 Mbps, and works with any standard WiFi router. The simultaneous dual band reduces interference, and with FastLane™ technology you can use both WiFi bands to establish one super high speed connection. It's ideal for HD video streaming and gaming, and is great for use with iPads, smartphones, laptops, and much more!
The EX3700 plugs into a wall outlet for a sleek solution to your WiFi dead zones. It blends into most environments and is barely noticeable, making it a great option for any room in your home or office.
Features of the EX3700 WiFi Range Extender:
- NEXT GENERATION WIFI - 750 Mbps† speeds
- ANTENNA - External antennas for better WiFi coverage
- DUAL BAND - Reduces interference for better connections to more WiFi devices
- 2 WIFI MODES - Extend your existing WiFi connection or create a new WiFi Access Point
- COMPATIBLE - Works with 802.11 b/g/n and 802.11 a/n/ac devices
- PUSH ‘N’ CONNECT - Secure push button WiFi connections (WPS)
- EASY INSTALL - CD-less setup makes it great for your mobile devices
- ETHERNET PORT - Connect a wired device such as a Smart TV or gaming console
WIFI ANALYTICS APP - Get a network status overview, check your signal strength, measure channel interference, and more
The EX3700 is great for:
- Reducing areas of low or no WiFi access (dead zones)
- Emailing, chatting, surfing, music and video streaming
- Online gaming
- HD Streaming
Specifications of the EX3700 AC750 WiFi Range Extender
Package Contents
- AC750 WiFi Range Extender (EX3700)
- Quick Start Guide
Warranty
- Localized to country of sale. For warranty and support details in your region visit netgear.com/about/warranty.
System Requirements
- 2.4 and/or 5GHz 802.11 a/b/g/n/ac wireless router or gateway
- ® Pentium® class PC
- Available USB 1.1 or USB 2.0 slot
- Microsoft® Internet Explorer 8.0, Firefox® 20, Safari® 5.1, or Google Chrome 25.0 browsers or higher
Standards
- IEEE® 802.11 b/g/n 2.4 GHz
- IEEE® 802.11 a/n/ac 5.0 GHz
- One (1) 10/100Mbps Fast Ethernet port with auto-sensing technology
Physical Specifications
- Dimensions: 55.17 x 67.17 x 39 mm (2.17 x 2.64 x 1.54 in)
- Weight: 130 g (0.29 lb)
Security
- Wi-Fi Protected Access (WPA/WPA2-PSK) and WEP
